| Prius Main Forum This is a discussion on LCD screen protector within the Prius Main Forum forums, part of the Toyota Prius Forums category; After many months of compulsively checking my MPG/consumption bargraph, I have noticed that the lower left corner of my LCD ... |
| Member Join Date: Jun 2005 Location: Orange County
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | After many months of compulsively checking my MPG/consumption bargraph, I have noticed that the lower left corner of my LCD has a nice little 'oil spot' on it. Do any of the priuschatters out there have any solutions for protecting the touchscreen? They make a whole variety of LCD protectors for PDA's and such, anyone make something like that specifically for the Prius? I currently use inkjet window decal material on my camera, although functional (and fairly cheap), I was wondering if there was a better solution out there. I am most annoyed by the 'moire' pattern that shows up on color LCDs. If you want to get REALLY fancy, you can make a CAD drawing (I use PCB software for this,) and print it 1:1 onto that material, that will allow you to cut holes irregular shapes, and most importantly multiple copies. After you do the scribing, strip the surface. BTW, if you go with the inkjet window decal stuff, you should soak it in water for a day and then gently rub the printable surface to get rid of the glue. If you don't do that, it's sticky when exposed to moisture. Woo hoo 51MPG!!! |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes, Sigma Automotive (one of the sponsors) sells one for $16. That sounds pretty good. You can see it here. Just scroll down until you get to Interior. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi, I had the same problem. I got a screen protector from this guy: http://cgi.ebay.com/ebaymotors/Screen-Prot...991845025QQrdZ1 Cleaned up the screen and placed the protector. Problem solved! It should be about $14 with shipping. :mrgreen: |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Nope, I would suggest: 1. clean the MFD very well 2. Start from one of the sides verifying the film is stright 3. use a credit card to apply the rest, and it will just stick to the MFD - look no hands Whatever you do, do not touch the inside part (that goes on the LCD) with your hand, this will leave your finger print there for ever. on the other hand it could be a good way to establish ownership if ever needed. |
| Senior Member Join Date: Jul 2005 Location: Los Angeles, CA
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Thanks, does it look pretty clear? I remember applying various film protectors to my PDA and it just didn't look right. Some were thick, others too glossy, and some even blurry. |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes, you'll get fingerprints on the protector too. I doubt if there's any such miracle device that doesn't. A can of compressed air to blow off any micro pieces of lint helps. Apply as the instructions describes and there should be no bubbles. The look is near transparent. It's very thin. Can barely tell it's there. It has a anti-glare, matte finish. Had mine since April and no signs of wear or peeling. It's a near perfect fit so align it carefully. |
| Display Screen Protector | rfloyd7522 | Prius Main Forum | 10 | 06-25-2007 07:13 PM |
| Screen protector for MFD? | acousticbiker | Prius Main Forum | 8 | 01-28-2006 10:57 PM |
| Screen Protector | DocToss | Care, Maintenance and Troubleshooting | 3 | 01-16-2006 07:41 PM |
| Screen protector | bozebuurman | Care, Maintenance and Troubleshooting | 32 | 12-04-2005 03:54 PM |
| Screen protector? | jtowndog | Prius Modifications | 6 | 05-11-2005 10:20 PM |
