| Prius Main Forum This is a discussion on Can I undo hitting the reset button? within the Prius Main Forum forums, part of the Toyota Prius Forums category; While showing off the car I accidently hit the reset button. Is there anyway to get my current tank mileage ... |
| Ruler of Omicron Persei 8 Join Date: May 2004 Location: Far-North Chicagoland
My Car: 2004 Prius Package: #9 Nominated 4 Times in 2 Posts TOTM Awards: 0 Friends: 15 | Sorry. I had to take Priapus in for work and they had to disconnect the 12v which wiped everything out. I ran the tank to the normal refill level (usually one bar blinking). Then, using the ODO reading, I calculated the number of miles driven between refills. Using the amount of gasoline I refilled with, I was able to calcualte the MPG. It shouldn't be too far off what the MFD would have shown. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(TonyPSchaefer @ May 18 2006, 09:54 AM) [snapback]257534[/snapback]</div> Quote:
| Senior Member Join Date: Jan 2006 Location: Somerville, MA
My Car: 2006 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Reading this thread I first read "Can I undo by hitting the reset button" and it reminded me of a xbox360 game called full auto where you have a rewind button for when you crash your car |
My Car: 2004 Prius Package: #9 Nominated 4 Times in 2 Posts TOTM Awards: 0 Friends: 15 | <div class='quotetop'>QUOTE(jeneric @ May 18 2006, 02:39 PM) [snapback]257637[/snapback]</div> Quote:
In the event that it's the latter, allow me to explain a little better since I did seem to skim quite a bit up there. We'll start with a completely filled tank and an ODO showing 15,478. Approximately 200 miles into the tank, I hit the [RESET] button or whatever. The numbers on the MFD are now officially bumpkiss. Refill occurs about 300 miles later and requires 9.8 gallons. The ODO shows 15,982. This means that I traveled 504 miles, consumed 9.8 gallons, and averaged a paultry 51.43 MPG. It's purely a measurement of how far I drove since the last refill and how much gas it took to get there. Unfortunately, if you do not have the ODO reading from the most recent refill, you can't do the math.
__________________ Proud father of Priapus: the '04 Tideland BC9 with an OEM EV button and sense of self-righteousness >>Current Mileage<< Spreading information and passing gas in the Greater Chicagoland area | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(TonyPSchaefer @ May 18 2006, 01:59 PM) [snapback]257686[/snapback]</div> Quote:
Anyway, I found it pretty interesting to split up a couple tanks, and reset after each little trip. Okay, it's 20 cents to go to the library and back, 50 cents to work this way, 75 cents that way. I used trip A to get the mileage to the tenth (then added .05 to round correctly) and trip B to make sure I was still accurate for the whole tank. You can check out the 2nd sheet in my spreadsheet if you're interested. | |
| Senior Member Join Date: Mar 2006 Location: Cambria, CA, USA
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm keeping a lifetime average on the computer, so I reset occasionally like jeneric does. (Sorry, I don't reset, but I reset the MFD.) |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Just a note. Be careful when cleaning the MFD. Don't clean it when on this screen, switch to the map or consumption screen. Have read about "premature reset," though I never experienced it myself, of course. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm still on my first tank and wondering if I should press 'reset' when I ultimately stop for a fill-up. What do most people do here? Reset with every fill-up, or never reset to see the lifetime average? No comment on 'premature reset'. ![]() |
| Consumption reset button | tman | Prius Main Forum | 30 | 09-07-2008 12:12 PM |
| Hitting the power button on accident at high speeds? | EmptyG | Prius Main Forum | 14 | 09-01-2007 03:10 PM |
| Amp blown? Any suggestions? Reset button? | PriusDreamer | Audio and Electronics | 7 | 06-04-2007 01:50 PM |
| Reset button going bonkers | jamminjay | Care, Maintenance and Troubleshooting | 5 | 08-18-2006 11:31 AM |
| NEW 06 nl7- reset button on the consumption screen | drpointer | Prius Main Forum | 4 | 01-15-2006 08:10 AM |
