Prius Main Forum This is a discussion on Panic button within the Prius Main Forum forums, part of the Toyota Prius Forums category; I agree with the above sentiment ... It is, after all, just a car. But I wonder why the car ...
Old 08-18-2006, 11:29 AM   #11
ramarren
But I wonder why the car would not power down if the key went out of range. Seems to me that would be a sensible security measure. I may not be thinking through all the possibilities, of course.
Godfrey
ramarren is offline
Old 08-18-2006, 11:54 AM   #12
HokieHybrid
HokieHybrid's Avatar
Godfrey did you consider the safety issue of a car just randomly shutting off at full speed? But imho when the fob goes out of range it should at least start beeping and flashing at you (inside...maybe outside).
HokieHybrid is offline
Old 08-18-2006, 12:16 PM   #13
Alnilam
The One in the Middle
Alnilam's Avatar
Package: #8
<div class='quotetop'>QUOTE(Godfrey DiGiorgi @ Aug 18 2006, 08:29 AM) [snapback]305323[/snapback]</div>
Godfrey Daniel!! (As my mentor W.C. Fields often said.)
I can't believe I read those words in the hallowed halls of PriusChat! The obvious result of a valueless liberal education.
All I can do is remember what the immortal Jack Benny said in similar circumstances:
With a gun pointed at your head and the impatient hijacker screaming in your ear, "Your Prius or your life!" there is but one correct answer....
"I'm thinking......I'm thinking...."
"Mars is essentially in the same orbit...Mars is somewhat the same distance from the Sun, which is very important. We have seen pictures where there are canals, we believe, and water. If there is water, that means there is oxygen. If oxygen, that means we can breathe." Dan Quayle
W6TWA
Coastal 1 1/4" Hitch
BT Brace
Toyota XM
Robin's MFD Shade
Motion Bypass Switch
Zaino Forever!
Coastal EV Package
ScanGuage II
Beltronics Vector 985 Radar Detector
Alnilam is offline
Old 08-18-2006, 12:46 PM   #14
markymags
<div class='quotetop'>QUOTE(Alnilam @ Aug 18 2006, 09:16 AM) [snapback]305365[/snapback]</div>
All I can do is remember the words of the immortal Jack Benny in similar circumstances:
It's nice to get a good laugh in the morning! =)
markymags is offline
Old 08-18-2006, 01:11 PM   #15
ramarren
<div class='quotetop'>QUOTE(HokieHybrid @ Aug 18 2006, 08:54 AM) [snapback]305341[/snapback]</div>
Um, I wasn't thinking about the case of being on the highway and tossing the fob out the window, no. :-)
I was thinking of the case where the door was opened and the fob left the interior of the car, went out of range. If the range is 16-30 feet, if someone hopped in and mashed the pedal to the floor while I was laying on the ground, it would shut off after 30 feet and coast to a stop. Can't be going all that fast in 30 feet and, well, if someone is trying to steal the car they're going to get out and go running away from my bruised and battered body, most likely... they don't want to return to me in the event that police or other people arrive.
Godfrey
LOL ... Old JB was a bit more of a fanatic than I would be. :-)
G
ramarren is offline
Old 08-18-2006, 01:28 PM   #16
Ichabod
Artist In Residence
Ichabod's Avatar
Send a message via AIM to Ichabod
Friends: 7
I could see it being a huge problem to shut the car off in motion. You're likely to experience that many more times than being carjacked too. As in the key-out-the-window-on-the-highway example above (maybe your small child threw your purse out the window) or any number of more routine circumstances.
And yes, it does beep at you if you take the fob outside the vehicle. Try it some time. My first experience with that was in a grocery store parking lot. I put the car in park and got out. For some reason it beeped at me a few times and the door wouldn't lock
2006 Barcelona Red Metallic - a.k.a. "The Professor" :: Accessories/Mods :: BT Tech Stiffening Plate - Engine Block Heater - OEM EV button - OEM Mud guards - Rear Bumper Protector :: Near-future :: ScangaugeII
Ichabod is offline
Old 08-18-2006, 01:42 PM   #17
Tom_06
Tom_06's Avatar
<div class='quotetop'>QUOTE(Ichabod @ Aug 18 2006, 01:28 PM) [snapback]305419[/snapback]</div>
<snip>...
An even more common circumstance: SKS and fob battery death. The fob battery will most likely die while the system is in use. As it is, it will just beep at you until you put the fob in the dash slot or replace the battery.
- Tom
Tom_06 is offline
Old 08-18-2006, 01:58 PM   #18
bruceha_2000
bruceha_2000's Avatar
Package: #8
I say, let him/her take the car, they can't get more than 500 or so miles before the car is unusable to them. Just let me get my cell phone out of the console to call my wife to pick me up. I'm sure they would trust me not to call 911.
bruceha_2000 is offline
Old 08-18-2006, 02:31 PM   #19
Three60guy
Package: #8
Send a message via ICQ to Three60guy Send a message via AIM to Three60guy Send a message via Yahoo to Three60guy
Well you could actually equip your Prius with technology that would tell you where it was.
No kidding:
Check this out.....
Real time vehicle tracking
$500 plus the cost of "pinging" the car when you want to find it. They said something like a "quarter" to do that.
You may laugh but who the heck knows? The Prius someday may become so popular that it might be a good candidate to being stolen. A solution like this could be an answer.
Ok, flame me. hehe
Three60guy is offline
Panic button on key fob not working harper42 Prius Main Forum 7 04-26-2008 08:58 PM
Panic Button on key fob marjam Prius Technical Discussion 5 06-29-2006 03:02 PM
Panic button on fob Oxo Prius Main Forum 15 02-06-2006 02:47 PM
Panic Button fleubis Prius Main Forum 8 12-31-2005 02:42 AM
Panic Button on Fob mswhealer Prius Main Forum 2 08-05-2005 08:50 PM
