Prius Main Forum This is a discussion on Seat Height -- Obvious flaw in otherwise great car within the Prius Main Forum forums, part of the Toyota Prius Forums category; I love my Prius. But nothing is perfect. One large and annoying flaw is the seat height and positioning. I'm ...
Old 01-22-2008, 02:17 PM   #1
nyprius
Nominated 2 Times in 1 Post
Default Seat Height -- Obvious flaw in otherwise great car
I love my Prius. But nothing is perfect. One large and annoying flaw is the seat height and positioning. I'm 6'1". The first time I got in my new Prius, I wanted to lower the seat and push it back more. After a while, I found a viable solution for moving the seat back -- I had a retrofitter who normally does this work weld steel to the front of the seat rails. This shifted the range of motion back three inches. Now I drive the car with the seat 2" farther back than a non-modified Prius can go. It's much more comfortable.
However, in spite of all the discussion about lack of seat height adjustment on PC, no viable alternative has been offered, at least for me. Someone discussed taking their seat apart and adding Corolla components. But I'm not a mechanic, so I can't do that. Others put in Recaro seats. But they are expensive and you lose the side air bags.
For some reason, US Toyota decided not to put seat height adjustment in the Prius. They have it in Europe and Japan. But not here. All Corolla models have it. The two higher end Yaris's have it. Only the low end Yaris does not have seat height adjustment. Does US Toyota think Prius buyers are equivalent to low end Yaris buyers? Movies stars and billionaires drive Prius's, because in some ways it's the coolest car on the planet.
I have the highest option package offered on the 05 Prius. My car has every option. But no height adjustment. It's like putting Yugo seats in a Mercedes. I cannot understand why US Toyota made this decision.
The Prius driver's seat position seems to be set for someone that's about 5'6". I like to have the seat back all the way up (rather than reclining back) when driving. As a result, the sloping down roof in front and back cuts off my vision out of the front and rear windshields. I often must crouch down to see what color traffic lights are. And I must look out the side mirror if I want to see more than a couple hundred feet behind my car.
Has anyone ordered the Prius driver's seat from Europe or Japan and installed it in their US Prius? Does anyone have any other practical suggestions for lowering the Prius driver's seat?
nyprius is offline
Old 01-22-2008, 06:34 PM   #2
drees
Default Re: Seat Height -- Obvious flaw in otherwise great car
Not me, but I also wish I could lower the seat by an inch or two and tilt the seat bottom a more from front to back. As it is now I feel a bit too much pressure on my buttocks and feel like I'm falling a bit forward out of the seat. I get used to it after a while, but it's a bit annoying as the car would otherwise be much better ergonomically!
drees is offline
Old 01-22-2008, 11:29 PM   #3
hefaust
hefaust's Avatar
I had the same problem with the seat making me feel as if I were falling forward. I solved the problem by taking 14 5/8" washers and shimming out the front bolts and under-rails of the seat. The process took me all of 15 minutes and now the seat is very comfortable.
hefaust is offline
Old 01-22-2008, 11:40 PM   #4
bestmapman
"Dream" Prius
bestmapman's Avatar
Here is an article from solar powered who added an adjustable seat.
bestmapman is offline
Old 01-22-2008, 11:47 PM   #5
nitschke65
Not entirely normal
nitschke65's Avatar
I'm a pretty handy guy, but after reading that article, I wonder if it wouldn't be easier to have three inches removed from my spine.
nitschke65 is offline
Old 01-23-2008, 05:56 PM   #6
clintd555
clintd555's Avatar
Ditto on the seat height adjuster. Huge over site by Toyota. Maybe the '09 will have one??
clintd555 is offline
Old 01-23-2008, 06:33 PM   #7
Earthling
Did you need longer bolts to do that? There is a local fastener shop that could supply me with longer, high-strength bolts if needed.
Harry
Earthling is offline
Old 01-23-2008, 06:56 PM   #8
GreenLady
GreenLady's Avatar
Well, I happen to love the seat height. (I'm 5'3" )
Seriously though, I agree that the lack of seat adjustments is a big downside. I love every thing about my Prius, but I wish the driver's seat was power adjustable.
GreenLady is offline
Old 01-23-2008, 07:33 PM   #9
westex39
I tried to do that too. Once I raised the seat up to install the washers the bolt hole was so misaligned I couldn't get it started. Can you please explain how you did this.
thanks,
Wextex
westex39 is offline
Old 01-24-2008, 12:01 PM   #10
kocho
My Car: 2002 Prius
thanks,
Wextex
Please, do - also wouldnt that mean that the rear bolts will be twisted back or the rail curved a little (less likely)? I thought about that but I also thought that the strength of the seat fasteners might be adversely affected. I suppose I need to take a look and probably even take the seat out to check that.
I'm 6'4" and the seat is both short and too much to the front. In my Camry I have room on the left behind the dashboard to fully stretch my left leg should I whish to do that (behid the foot support) - nothing like the cramped space on the left in the Prius. And my right leg is not up at the knee nearly as much as it is in the '02 Prius....
If anyone has fitted a Corola seat or another "stock" seat - please share with details. I'd be interested to learn more.
kocho is offline
