Prius Main Forum This is a discussion on Magnetic signs . . . but within the Prius Main Forum forums, part of the Toyota Prius Forums category; I had this great idea. When I am doing pulse a& glide, or slow cruise control, I often wave traffic ...
Old 04-26-2008, 10:43 PM   #1
Doc Willie
Shuttlecraft Commander
Doc Willie's Avatar
Friends: 7
Default Magnetic signs . . . but
I had this great idea. When I am doing pulse a& glide, or slow cruise control, I often wave traffic by me, rather than pull over completely. So I figured I would get some magnetic signs made that could encourage drivers to pass me by and let them know what I am up to. See photos.
So I picked the up, walked to the back of the Zhang Heng, slapped the on the hatchback next to the license plate and . . . they fell off ! the d****d stuff is aluminum.
So now I am stuck with two signs and now way of attaching them. Permanent installation is out of the question.
I am kicking around a number of ideas. Any suggestions welcome, or let me know of anyone with a steel trunk who would like some brand new signs for fuel economy runs.
2207 Prius-class Shuttlecraft, Level 5 technology
Exterior: Starfleet Graphics; Antigrav Generators; Velocity Transducer Disks
Performance: Toroidal Velocity Transducer Resize; Auxiliary Engineering Computer; Intermix Pre-Heater; Structural Integrity Reinforcement; Stealth Mode
Interior: Main Screen Security Access w/ In-flight Stellar Cartography; Aft Motion Warning System Upgrade; Weapons and Engineering Controls
More
Doc Willie is offline
Old 04-27-2008, 12:19 AM   #2
Bill Lumbergh
Enabling ISR ATOs for OEF/OIF
Bill Lumbergh's Avatar
Package: #1
Default Re: Magnetic signs . . . but
Utilizing some small squares of steel and some band iron you might be able to fabricate some brackets to hold your signs. You could mount them using the license plate screws.
Drill a pair of holes in the band iron and bend it so it conforms to the body, then tack weld the steel squares to either end of the band iron. You can then mount your magnetic signs and removal is a simple two screws.
In the below pic the green is the band iron and the red represents the steel squares.
Edit: I just figured out what you need: a Magnetic Grey Prius.
Bill Lumbergh is offline
Old 04-27-2008, 12:43 AM   #3
Rae Vynn
Resident Witch
Rae Vynn's Avatar
Friends: 43
Yes, yes... we've had that happen, when trying to affix a magnetic bumper sticker...
... the only place it would stick is the doors. Sigh.
You could get printable vinyl bumpersticker sheets, and print it out from your PC (or Mac)... and leave them on all the time. They will peel off pretty easily, but wouldn't necessarily be reusable...
Well, there is some reusable "stickers" sheets that you can get, too.
How about tape? a good double-sided tape, around all four edges?
Rae Vynn is offline
Old 04-27-2008, 12:17 PM   #4
inventor00
Orange County Prius Club
inventor00's Avatar
We got our vinyl stickers for the back windows- big HYBRID - see avatar- at Big City Images
inventor00 is offline
Old 04-27-2008, 01:30 PM   #5
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 5
For the back? Either a permanent bumper sticker or reuseable window clings.
OR you can put them on the side doors, but they won't be seen from the back.
Godiva is offline
Old 04-27-2008, 09:23 PM   #6
Doc Willie
Doc Willie's Avatar
Friends: 7
<IMG style="; WIDTH: expression(this.width > 800 ? 800: true); max-width: 800px" alt="" src="http://i19.photobucket.com/albums/b161/rodgerboles/LicensePlate.jpg" border=0>
I think we are getting close. These signs are 8x8" and would not fit into the red area indicate. They are mean to go onto the spaces of the trunk on either side of where those red squares are indicated.
What about some sheet metal running from the edge of the license plate to the edge of the trunk? Need to figure out how to attach it.
Old 04-27-2008, 10:54 PM   #7
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 5
Originally Posted by Doc Willie View Post
I
What about putting some sheet metal on the inside of the trunk area? Take the inside lining out, attach it to the outside with adhesive or something and then put the lining back. Would the magnetic signs be strong enough to detect the steel through the aluminum?
Godiva is offline
Old 04-28-2008, 01:29 AM   #8
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
You can also try getting some natural magnets that are really strong and mounting them inside the trunk to hopefully generate a large enough field that will attract the signs...
Another solution: velcro should be more then enough to attach the sign to the back.
Bob64 is offline
Old 04-28-2008, 01:39 AM   #9
patsparks
Uneducated bird-brain Aussie
patsparks's Avatar
Friends: 11
Double sided tape and WD40 or RP7 to remove it when you want it off.
Be very careful with steel near aluminium as it my cause electrolysis and corrosion.
patsparks is offline
Old 04-28-2008, 08:17 AM   #10
Cliff Archie
Cliff Archie's Avatar
velcro?
Cliff Archie is offline
Sexist Street Signs kDB Fred's House of Pancakes 15 05-25-2007 01:26 PM
Bush ignores laws that he signs JackDodge Fred's House of Pancakes 18 06-28-2006 05:17 PM
Top 5 Signs Gas Is Too Damn Expensive eastercat Fred's House of Pancakes 5 12-03-2004 02:21 PM
Arnold signs carpool bill brosnan Prius Main Forum 6 09-30-2004 02:20 PM
Vital signs monitoring LKFSE Audio and Electronics 0 12-23-2003 05:21 PM
