| Prius Modifications This is a discussion on Tire Upgrade within the Prius Modifications forums, part of the Toyota Prius Forums category; Originally Posted by dwreed3rd Thanks Boo! Lucky if we ever get the call. On the list since May. Ditto on ... |
| | #281 | |
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 13 | Quote:
Thanks for the wise tips on tire wear. They make a lot of sense. Here in NYC where we frequently have to pull in and out of parallel parking spaces that are only a foot or two longer than our car, we tend to turn the wheel a lot while the car isn't moving. I'm going to try to avoid doing that whenever I can. Last edited by Boo; 07-11-2008 at 05:46 AM. | |
| | #282 |
| Senior Member Join Date: May 2008 Location: Marietta, Ga
My Car: 2008 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Yea Boo! Parallel parking's rough on tire wear. Just let it inch/creep a little to release the rubber as you turn the wheel. Last edited by dwreed3rd; 07-11-2008 at 10:51 AM. |
| | #283 |
| Senior Member Join Date: Feb 2008 Location: hollywood
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 13 | DWREED3RD - hey, i just saw this thread on tires. i recently purchased the bridgestone potenza's. they're awesome! good wear (supposedly) and good traction, dry and wet. i would recommend them. makes the car handle on rails without a big hit on the mpg. my car is NOT an original touring, it's been converted. so, with the integrity's, i was getting about 47.4-47.5 mpg, now, it's at 47.2. i know i lost some mpg's, but my goodness, it's a super handling car. |
| | #284 |
| Member Join Date: Apr 2006 Location: Winston Salem NC
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Michelin Pilot Exalto A/S Be very careful buying these as replacement tires. I have been disappointed with these tires (noisy and bad high speed handling) and I am still a Michelin die hard (have other Michelins on my other 2 cars). I bought 195/65/15's to replace my original 185/65/15's half worn Goodyear's thinking I would get a quieter tire (Michelin) AND better handling (wider tire). These Michelin's are almost as noisy as the original Goodyear's BUT they do handle better in WET traction. I feel a lot more confident in rainy weather than the Goodyear's that came on the car. I have NOT driven them in Winter weather yet. Just realize that my experience is having to run them at lower pressure of 33 lbs vs. any higher pressures (had 35 in them from the day I bought them new at Sam's Club) due to handling issues at high speeds (65 mph and over). Handling is HORRIBLE with the prior mentioned speed and tire pressure of 35 lbs. The car darted and was hard to hold on the road period. Anything lower than 60 MPH I could not tell any difference in handling with either tire at either pressures. My opinion. Since recently lowering the pressures to 33 lbs they handle fine now at 70 mph on dry roads but I would say no better than the Goodyears (remember I am now talking dry pavement). I will NOT buy these Michelin's next time but would spend more ($93/piece) on other Michelin's now that I know what I know about Pilot Exalto's A/S.
__________________ Mods: Heated seats and power lumbar supports by Rostra Under dash courtesy lights from Monolith Intl Trading Auto Door lock from Coastal Tech Navigation bypass kit from Coastal Tech XM add on kit Trailer hitch from Coastal Tech Avg MPG 42 in 28K miles since May 2006 Last edited by lilrdwgn; 07-13-2008 at 10:01 AM. Reason: Did not give enough info for my first post |
| | #285 | |
| Senior Member Join Date: Apr 2007 Location: S.F. Bay Area
My Car: 2007 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| | #286 |
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Sorry I did not post in the earlier version. In regards to the Michelin Pilot Exalto A/S tire, I have NO mods to the suspension of my car nor the body (braces) but have wondered if the tower or lower/ under car brace would help? in my car's handling? And yes, the tires are correctly mounted. I watched the installer and he showed me if I ever had them rotated or repaired somewhere else, to make sure they were put on the car in the correct direction. Thanks for telling me to edit my original post. I still like Michelins, just not Pilot Exaltos on Prius's. |
| | #287 | |
I am able to run higher inflation pressures than you are (38F/36R; I have gone higher, but the 38/36 number seems to be a nice compromise between higher mpgs vs. ride harshness) with no handling problems, so something is amiss. You haven't mentioned the tire or wheel sizes you are using. Could you provide that data? Last edited by apriusfan; 07-13-2008 at 02:14 PM. | |
| | #288 | |
| Still a Laker's Fan Join Date: Mar 2008 Location: Southern California
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Where did you buy the suspension braces? Do you have the website address? Also, did you install them yourself? Thanks! Quote:
| | #289 | |
Re. Installation, the front suspension braces are pretty easy to install. The rear brace (A-frame shaped item) requires some spacers to be able to clear the gas tank. I used flat washers and longer bolts to get the necessary clearance. After installing everything, I would have the car's alignment reset in case anything got shifted during installation. | |
| | #290 |
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Thanks for the info! Do you need to install both or can you just install the front braces for the steering? |
| Touring Edition Tire Upgrade | wblovett | Prius Modifications | 37 | 06-25-2008 02:43 PM |
| Tire Upgrade - Walmart | ibcs | Prius Main Forum | 3 | 11-19-2007 11:21 AM |
| Tire upgrade and pressure sensor question | Dr Ed | Prius Technical Discussion | 16 | 08-20-2007 06:01 PM |
| Tire Upgrade | Kramer | Prius Main Forum | 16 | 10-10-2006 10:39 PM |
| 17" Tire Upgrade Reccs? | Ken S | Prius Modifications | 5 | 09-12-2006 03:41 PM |
