Prius Modifications This is a discussion on Tire Upgrade within the Prius Modifications forums, part of the Toyota Prius Forums category; Originally Posted by Wa1hog ...I have noticed that my speedometer is usally 1 to 2 MPH faster than what my ...
Old 08-05-2008, 09:03 PM   #331
hyo silver
awaaay
hyo silver's Avatar
Friends: 32
Originally Posted by Wa1hog View Post
...I have noticed that my speedometer is usally 1 to 2 MPH faster than what my GPS says Im going.
Originally Posted by F8L View Post
...The stock Prius tire size in the U.S. is 185/65/15. Overall you want to try and maintain the stock 24.4" diameter.
This may have been discussed sometime in the last few hundred posts, but I'm not about to reread the whole thread to find out. My apologies if you've heard this before.
Knowing that the speedo reads a bit fast with the stock tires, wouldn't a tire that's slightly smaller improve the speedo's accuracy? I'm thinking the TT's revolutions per mile of 862 as a replacement for the Integrity's rpm of 855 is just about perfect.
hyo silver is offline
Old 08-06-2008, 12:05 AM   #332
nyprius
Nominated 2 Times in 1 Post
Default Re: Tire Upgrade
Originally Posted by mtagg49 View Post
Thanks for the great research - have you had any experience with the 195/60 TT in snow?
Mike from Chappaqua
The TT's are great in the snow and rain, as well as on dry pavement. They're an excellent all around tire. My only complaint is that they've gotten noisy now that I have over 40,000 miles on them. The tread will probably last to 60,000 or 65,000 miles. Not 80,000.
When it's time for new tires, I'll try something new. I want a tire that has excellent handling like the TT, but is quieter. I'd also rather get a non-directional tire next time. This way I can move the tires to the other side of the car if I have a pulling problem that isn't fixed by alignment. I have a slight pull now and have to live with it. I'm not sure if the pull is caused by the tires since I can't switch them over to the other side to test, unless I take them off the rims, which I'm not going to do.
nyprius is offline
Old 08-07-2008, 12:01 PM   #333
jdenenberg
jdenenberg's Avatar
Send a message via Skype™ to jdenenberg
Friends: 8
No, smaller tires will make the speedo read higher. You need a tire with fewer revs/mile to adjust the speedo lower (note that this will appear to lower your MPG by the same %, but the change is not real).
JeffD
jdenenberg is offline
Old 08-07-2008, 12:27 PM   #334
dwreed3rd
Package: #3 Touring
JeffD
jdenenburg: I don't know if Hyo Silver has an SGII, but if so, I believe there's a mileage adjustment. In fact, I know there's one. I went crazy trying to set it for the Avalon. That's when I realized the Georgia's mile markers are all screwed up with all the new construction on GA 400. Anyway just a thought.
dwreed3rd is offline
Old 08-13-2008, 01:22 AM   #335
kcribk
Has anyone researched (or had experience with) the Yokohama Avid T4 or the Yokohama YK520?
kcribk is offline
Touring Edition Tire Upgrade wblovett Prius Modifications 37 06-25-2008 02:43 PM
Tire Upgrade - Walmart ibcs Prius Main Forum 3 11-19-2007 11:21 AM
Tire upgrade and pressure sensor question Dr Ed Prius Technical Discussion 16 08-20-2007 06:01 PM
Tire Upgrade Kramer Prius Main Forum 16 10-10-2006 10:39 PM
17" Tire Upgrade Reccs? Ken S Prius Modifications 5 09-12-2006 03:41 PM
