Prius Modifications This is a discussion on Quickfix for improved front/rear visibility within the Prius Modifications forums, part of the Toyota Prius Forums category; I'm 6'0" and, as others have described, have trouble seeing some stoplights without leaning over the wheel to look up. ...
Old 06-10-2007, 08:54 PM   #1
hole_shot58
I'm 6'0" and, as others have described, have trouble seeing some stoplights without leaning over the wheel to look up. Until I decide how to lower my driver seat, I've got a quick fix you might like to know about. Additionally, my base model lacks the one option my wife really liked, the backup camera. I've got that (sort of) figured out too!
I purchased a 3M wide angle viewer, sized for a passenger van (6"x8") at an RV supply shop. I cut it into two pieces, lengthwise, right through the "optical center". This is about 2" below the Top, where you see the circular pattern converge to a point.
Following the install instructions, the smaller Top section goes just below the top edge of the windshield, nearly centered over the steering wheel. Now I can see stoplights quite easily.
The bottom section is just the right size for the nearly vertical piece of glass in the hatch, giving me a clear view of the area behind my car, at least enough for parking purposes. Not as good as a camera, but a big improvement over nothing at all.
Pictures attached (I think - first post). Hope this is useful.
Cheers!
quickfix-improved-front-rear-visibility-3mwideview.jpg  quickfix-improved-front-rear-visibility-forward_view.jpg  quickfix-improved-front-rear-visibility-outside_view.jpg  quickfix-improved-front-rear-visibility-rear_view.jpg  quickfix-improved-front-rear-visibility-rear_closeup.jpg
hole_shot58 is offline
Mud guards front & rear - any MPG comments ?? wtfjr Prius Main Forum 7 10-26-2006 03:06 PM
Rear visibility with luggage hockeymulder Prius Main Forum 7 06-08-2006 06:20 PM
Rear visibility without the camera, good or bad? BoosPrius Prius Main Forum 12 04-19-2006 12:04 PM
Rear Window Visibility nancyr Prius Modifications 9 05-07-2005 05:56 PM
Rear Visibility skruse Prius Main Forum 2 11-08-2004 01:16 AM
