| Prius Modifications This is a discussion on going lower. . .inserts. . . within the Prius Modifications forums, part of the Toyota Prius Forums category; I applaud your work and efforts; I like the car lowered. I dropped mine withthe TRD suspension andit came down ... |
| lower, suspension |
| | LinkBack (4) | Thread Tools |
| | #21 |
| Senior Member Join Date: Dec 2004 Location: San Ramon Valley, CA, USA
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I applaud your work and efforts; I like the car lowered. I dropped mine withthe TRD suspension andit came down about 1". Not enough for me but given my commute and number of miles that will have to do. |
| | #22 | |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Quote:
So with the stock springs on it road pretty nice... that's stock springs with the lower mount still raised right? | |
| | #23 |
| Senior Member Join Date: Oct 2007 Location: San Diego, CA
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm sure he is measuring ride height from the center of the wheel to the fender lip - that is the "proper" way to measure ride height as different size wheels/tires, don't affect the measurement. |
| | #24 | |
| Member Join Date: Nov 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | Quote:
the drivers side gap is just about right but the passenger side gap is up to 1/2 inch wider!! just nuts!! i thought i was very careful to reposition and weld the mounts equal on both sides soo i've been scratching my head about what went wrong? i could see being 1/4 inch off but 1/2 is just too much!! the car rides too soft in front right now soo my plan is to reweld the drivers side mount up about 1/2 inch and put my blitz springs back in leaving the passenger side alone. that will hopefully even out the ride in front. . . | |
| | #25 | |
now lowering it just another inch makes those speedbumps and steep driveways a concern which were not before!! | |
| | #26 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | final ride height. . .for now. . . i put the blitz springs back in front and rewelded/repositioned BOTH lower mounts to even out the front. . . front wheel center to fender lip: 12 1/4 inches rear wheel center to fender lip: 11 3/4 inches |
| | #29 |
| Junior Member Join Date: May 2008 Location: fairfield
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I understand that you replaced ypur original springs with blitz springs. You also did some modification with your suspension. My question is this; If I simply replace my original springs itself would the outcome be; At least 1" lowered? Would I need an alignment? thanks. What are your suggestions. |
| | #30 |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Anytime you are switching out springs which raise/lower a car you need to have it realigned. BTW the TRD suspension lowered my car about 3/4". |
| LinkBack to this Thread: http://priuschat.com/forums/prius-modifications/46059-going-lower-inserts.html | ||||
| Prius Modifications: Blogs, Photos, Videos and more on Technorati | This thread | Refback | 05-03-2008 01:44 PM | |
| Filling Tires with Snake Oil « Jim’s Garage | This thread | Refback | 04-23-2008 10:01 AM | |
| Mercedes 40-MPG Diesel Hybrid: Cleanest SUV on the Planet : Gas 2.0 | This thread | Refback | 04-22-2008 07:46 PM | |
| EBH--lower wattage and lower temp...? cold related? | efusco | Prius Modifications | 3 | 02-03-2008 02:30 PM |
| New Tires = Lower MPG???? Help!! | s.e.tx_parrothead | Fuel Economy | 4 | 06-12-2007 12:13 AM |
| New fton wiper inserts streak and skip - may have solved it? | SebMike | Care, Maintenance and Troubleshooting | 0 | 02-14-2007 05:59 PM |
| Strange Inserts | bogeybob513 | Prius Main Forum | 2 | 12-22-2006 02:00 PM |
| New Wipers or New Wiper inserts? Driver side wiper size? | Eug | Care, Maintenance and Troubleshooting | 7 | 01-23-2005 12:45 PM |
