| Prius Modifications This is a discussion on Prius Auto Headlights when dark Mod within the Prius Modifications forums, part of the Toyota Prius Forums category; One more problem with my prius is its not smart enough to turn on the headlights when dark. For such ... |
| Senior Member Join Date: Mar 2008
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | One more problem with my prius is its not smart enough to turn on the headlights when dark. For such a highly technical vehicle it baffles me why they leave off a $10 dollar auto headlight switch. I have tracked down a unit that needs to be fitted with some slight tapping into the system wire. Its basically a light detector and a relay/ecu. You can modify the unit to have time delays on/off etc. I will be adding this to my car this weekend. I will take pictures of the mod as I add it. Heres a picture of the unit. It looks way more complicated then it is. I will only use 2 of the wires and cap off the others. The pictures.... Last edited by problemchild; 05-15-2008 at 02:57 AM. |
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Sorry mine is either on or off. On dims the dash screen and uses extra fuel during the day. Page 110 in my owners manual is child restraint chair installation. There is a Type A switch and a Type B switch. Mine is 2 position. Thats in the same owners manual on page 150. Last edited by problemchild; 05-15-2008 at 11:33 AM. |
| Junior Member Join Date: May 2008 Location: michigan
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | If your Prius was delivered in Canada you have an "auto" position on the headlight stalk. Those sent to the USA and elsewhere don't have the extra position. Page 150 of the 2008 Prius manual explains the auto position "if so equipped". American Prius doesn't have this option ma |
| Member Join Date: May 2008 Location: Southeast PA
My Car: 2008 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
DRLs do not light up the rear of the vehicle and full headlights do. Uses more fuel ..... ???? If it makes me more visible to other drivers it is worth it when driving the freeways and interstates. I DO AGREE that it should be a standard accessory. My $18K Chevy contractor Silverado came standard with an automatic light sensor that works extremely well for turning the lights off and on without any input from myself. Can we retrofit the Canadian stalk and any other needed hardware and stay OEM? That would be my preferred choice for the upgrade. | |
| Auto headlghts when dark Any1 interested? | problemchild | Prius Modifications | 28 | 05-23-2008 07:30 PM |
| Auto-on Headlights: Why didn't my Prius have it? | Aaron | Prius Main Forum | 13 | 04-03-2008 02:37 PM |
| Override dark background on nav map screen when headlights on | 4n6 | Audio and Electronics | 5 | 10-13-2007 07:36 PM |
| When my headlights are on, my dashboard is dark | charlotte96 | Care, Maintenance and Troubleshooting | 14 | 01-12-2007 04:23 PM |
| Auto Headlights | Alnilam | Prius Main Forum | 9 | 06-09-2006 01:44 PM |
