Prius Modifications This is a discussion on Has anybody ever... within the Prius Modifications forums, part of the Toyota Prius Forums category; Swapped another motor and/or transmission into a Prius? I am starting a project where I am going to put a ...
ever...
Old 07-21-2008, 09:18 PM   #1
2jzprius
Nominated 1 Time in 1 Post
Default Has anybody ever...
Swapped another motor and/or transmission into a Prius? I am starting a project where I am going to put a 2jz from a salvaged supra into my Prius. I am looking for others insight as to how hard this project will be.
2jzprius is offline
Old 07-21-2008, 10:39 PM   #2
justlurkin
justlurkin's Avatar
Default Re: Has anybody ever...
If you want to swap a different gasoline engine into the Prius, its driveshaft will need to drive the carrier ring for the planetary gears in the Power Split Device. You will then need to figure out how to hook it up to the electronics that controls the Hybrid Synergy Drive to work with that different engine, and hack the HSD control software to work with that new engine too. I'm not sure if it's possible to use an Otto-cycle engine with the Hybrid Synergy Drive-- All of the HSD-powered cars use an Atkinson-cycle engine if I remember right (not sure?).
That's if you want to retain the full hybrid capabilities of the Prius-- ability to shut off or start up the gasoline engine on the fly, use of regenerative braking, etc.
If you don't care about hybrid capabilities at all, then basically you are just putting a Prius body shell onto a Supra chassis with a conventional engine and tranny.
justlurkin is offline
Old 07-21-2008, 10:45 PM   #3
galaxee
uphill battling
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 19
step 1: clear enough space for the engine and transmission. sorry, but i don't see that happening. have you seen the two engine compartments? night and day.
galaxee is offline
Old 07-21-2008, 10:48 PM   #4
2jzprius
I don't plan on using any hybrid parts. I am going to just gut the car down, and install the Supra drivetrain. If the motor doesn't fit in the front, I can just put it in the rear of the car, and fabricate my way out of there. I plan to have everything done by the new year. As of right now, I am working on taking all of the parts off the supra.
2jzprius is offline
Old 07-21-2008, 11:18 PM   #5
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 5
Why not just leave everything on the Supra and find a way to put the Prius body on the Supra frame. Seems a lot easier.
(This project also seems kinda stupid. I mean...what's the point?)
Godiva is online now
Old 07-21-2008, 11:22 PM   #6
Friends: 5
Why?
Old 07-21-2008, 11:25 PM   #7
2jzprius
I want to make a sleeper which I can take to Bay Area street races. I'm sure I'll be laughed at when I first pull up, but then when I race for pink slips - I'll be the one laughing.
2jzprius is offline
Old 07-22-2008, 12:18 AM   #8
justlurkin
justlurkin's Avatar
If you want to gut a Prius, you will have A LOT of fabrication to do, including:
- Building a steering and suspension system. The Supra's engine, tranny and rear-wheel-drive will demand a different kind of layout and suspension than the Prius's front-wheel-drive transaxle and steering. The center of gravity will also be altered since you will probably have to go to a mid-engine layout.
- Building a new throttle, brake and transmission control system. In the Prius, those three things are not mechanical but electronic ("drive-by-wire") because of the Hybrid Synergy Drive.
- Custom underframe to support the engine, transmission and suspension. All that gutting is going to compromise the stiffness of the Prius frameless unibody construction.
It would probably be a lot easier if you modified a Supra chassis to take Prius body panels instead.
Old 07-22-2008, 12:25 AM   #9
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 5
You're going to win pink slips in a Supra?
Ok. Now I know the point. And it is stupid.
Old 07-22-2008, 08:49 AM   #10
Stefx
I think you're already being laughed at.
Stefx is offline
