| Prius Modifications This is a discussion on Technical specs EV-MOD within the Prius Modifications forums, part of the Toyota Prius Forums category; I attempted to purchase the EV -Mod from Coastal, however the do not ship to Canada. Can anyone provide the ... |
| ev-mod, evmod |
| Member Join Date: Apr 2008 Location: Vancouver
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I attempted to purchase the EV-Mod from Coastal, however the do not ship to Canada. Can anyone provide the techinal specs of the component connecting the 3 wires? It appears to be a small circuit board of some kind. I'll build my own if I can obtain the details. or: is someone has a side 'on-line' or e-bay business using PayPal that could purchase on my behalf, I will purchase the mod from them and then arrange shipping, I am open for that as well. Thank you |
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Not sure what technical specs the Coastal product requires or whether it's in the form of a circuit board. But you can take a somewhat different and much cheaper approach with only a simple Radio Shack pushbutton switch and some wire. And it's instantaneous, whereas the Coastal switch has a delay of several seconds. See this writeup of my installation with a link back to the original instructions authored by Evan Fusco. |
| Senior Member Join Date: Mar 2008 Location: kentucky
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Do not buy an EV-mod save your money and do it yourself. I did the headlight switch mod it costs $0 if you have a piece of wire and no one knows you have it and its also instantaneous just go to the write up by Evan Fusco.. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | there's documentation on a button around here somewhere. all you have to do.. for a DIY... is find the two pins. connect wires, and put an instant switch in... like a door bell. I have a nice little white doorbell with gold trim. i drilled a hold in the black cover piece and hot glued the switch in place. |
| Prius Noob Join Date: Jul 2008 Location: Swansea, UK
My Car: 2008 Prius Package: T4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
What headlight switch mod ? btw as a UK owner I find the EV button uses more fuel in the long run if you use it a lot. Last edited by Dozzer; 09-02-2008 at 05:30 AM. | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | If you want to pay for an over priced plagerized, probably patent infringed version you can try juicedhybrid.com....they probably will ship to you for an exhorbatant price. But you'll be much happier with a DIY mod based upon my original write up.. |
| Specs and pics | KandyRedCoi | Tesla Roadster | 28 | 05-27-2008 07:12 AM |
| What ACEA Specs should I be looking for? | FL_Prius_Driver | Care, Maintenance and Troubleshooting | 6 | 11-29-2007 10:00 AM |
| Prius Specs | babsrocks | Prius Main Forum | 4 | 04-12-2005 09:29 AM |
| Tech specs for HV battery? | mspencer | Prius Main Forum | 15 | 03-11-2005 08:39 PM |
