Prius Modifications This is a discussion on Can Nav be added later?? within the Prius Modifications forums, part of the Toyota Prius Forums category; As I see more and more Prius' available on the lot is it possible to add the Nav (GPS) later ...
Old 06-13-2005, 09:06 PM   #1
kaptaink
kaptaink's Avatar
Default Can Nav be added later??
As I see more and more Prius' available on the lot is it possible to add the Nav (GPS) later thru the dealer? I know of 3 cars available in my area next week with pkgs 3 and 5 but I would like the GPS built in but dont necessarily want to spent and extra $5000 just to get it.
Thanks for your help.
kaptaink is offline
Old 06-13-2005, 10:00 PM   #2
Nominated 1 Time in 1 Post
Friends: 24
not the OEM one. There are a number of less expensive aftermarket products that people seem to be happy with.
I love my NAV...despite the complaints of innaccuracy I think once you get it set up how you want it is very convenient. Just the other day we found a restraunt we knew the name of, looked it up in the nav, hit the info button, hit the phone button and called them to get reservations via the bluetooth phone connection, then navigated our way to the restraunt later that day. No aftermarket product's going to give you that kinda convenience.
efusco is offline
Old 06-14-2005, 09:34 AM   #3
DanMan32
I found one address inaccuracy. There is a church where I was going to attend a concert. It was on the way home from work, so I went there to get tix. While I was there, I marked the point and stored it as a memory point.
later I heard the address on the radio, entered it in and compared the locations of the flags. The point made by address was about a mile north of the actual location!
Otherwise, I find the nav quite useful.
DanMan32 is offline
Old 06-14-2005, 05:32 PM   #4
jfh3
Default Re: Can Nav be added later??
<div class='quotetop'>QUOTE(kaptaink\";p=\"98128)</div>
Thanks for your help.[/b]
Is it POSSIBLE? Yes, but I'm sure it'll end up costing you at least as much as whatever delta you'd save by not getting package #6 in the first place, and probably more.
(Package 5 - never understood why anyone would want that instead of package 4. Package 5 should've been 4 + the homelink mirror)
jfh3 is offline
Old 06-15-2005, 01:38 AM   #5
NuShrike
my other Mobile Suit is a ...
NuShrike's Avatar
<div class='quotetop'>QUOTE(efusco\";p=\"98156)</div>
Just the other day we found a restraunt we knew the name of, looked it up in the nav, hit the info button, hit the phone button and called them to get reservations via the bluetooth phone connection, then navigated our way to the restraunt later that day.  No aftermarket product's going to give you that kinda convenience.[/b]
I'm reading the TomTom BT navigator gives you this exact same functionality and convenience. That might be something to lookup.
TomTom is also looking to integrate traffic information with the GPS path mapping for the Americas? soon. Seems to be available in Britain already. This does then put it one leg above the built-in GPS.
NuShrike is offline
Old 06-15-2005, 09:06 AM   #6
Friends: 24
I googled the Tom Tom and it looks like a pretty good program, but the only BT connection seems to be for the GPS....do you have a link discussing the BT connection to the phone?
efusco is offline
Old 06-15-2005, 02:39 PM   #7
DanMan32
Well, sure its possible. You would need to replace the MFD and the steering wheel controls, add NAV ECU, microphone and GPS antenna, create wiring harness. You would need the harness to intercept a speaker so it could take it over, add mute line to silence radio (for BT), B+, ACC, RGBS to MFD, connect to microphone, which normally routes through MFD.
DanMan32 is offline
Old 06-15-2005, 06:48 PM   #8
NuShrike
NuShrike's Avatar
<div class='quotetop'>QUOTE(efusco\";p=\"98610)</div>
I googled the Tom Tom and it looks like a pretty good program, but the only BT connection seems to be for the GPS....do you have a link discussing the BT connection to the phone?[/b]
Sure, right here.
Seems to be available starting June/2005 (NOW) too.
NuShrike is offline
Old 06-15-2005, 08:59 PM   #9
jfh3
Which is why I said it would probably cost more after the fact than just getting a package 6 in the first place.
jfh3 is offline
Old 06-16-2005, 02:01 PM   #10
DanMan32
Sorry jfh3, I thought I read an emphasis 'but is it POSSIBLE?' Must be imagining things.
DanMan32 is offline
Finally added the EV mod JimboK Prius Modifications 26 08-26-2007 10:42 AM
Can Fog Lights Be Added? Tenor1 Prius Modifications 4 08-05-2007 11:12 PM
D/R Added Value stanleyjohn Prius Main Forum 1 01-25-2007 06:35 PM
What I've added to my Prius vinnysca Prius Modifications 5 09-03-2006 10:09 AM
To those who added a sub to the car murzar Audio and Electronics 0 10-23-2004 04:03 PM
