| This is a discussion on 70 mph EV only mode. within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; Wow. Chris Ewart, one of the fantastically talented reverse-engineers of the plugin prius scene, has just released this video: YouTube ... |
#1 |
| Mum to two prius! Join Date: Jan 2007 Location: Bristol, UK
My Car: 2007 Prius Model: Package: T Spirit Thanks: 0
Friends: 6 | Wow. Chris Ewart, one of the fantastically talented reverse-engineers of the plugin prius scene, has just released this video: He's figured out how to get 70 mph all electric performance out of the Prius and has also figured out how to get past the limitations of the OEM motor controls. I suspect he's done something similar to the mod done by Toyota in their OEM prius plug ins.... Whatever and however he's done it. Congratulations Chris. I can't wait to see it in a conversion soon. (apparently the conversion high speed option will be offered by Plug-In Home soon)
__________________ Twice the trouble. "Velma" 2004 T4 with added PHEV. 100 mpg+! "Daphne" 2007 TSpirit ------------------------------------------------- http://www.aminorjourney.com Last edited by aminorjourney; 06-10-2009 at 01:41 AM. |
| Junior Member Join Date: Jun 2009 Location: undercover
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 0
Friends: 0 | Exciting news, so that was the upcomming big press release they and friends talked about! Well, we knew that >52mph is technically possible to get out of Toyota's HSD, but is it safe for the MG1&MG2 over the longhaul? For more info/links on Ewert Energy (formerly engaged in CalCars PriusPlus) projects check my posts at page #28 of your "Bristol PHEV" thread.. |
| The Following User Says Thank You to Mesuge For This Useful Post: | dave77 (08-19-2009) |
Friends: 20 | Excellent work! It looks like they were drawing about 100A at around 200V, about 20 kW or about 27 hp. There were some interesting spikes but short of doing a frame-by-frame analysis, this was just a raw impression. Bob Wilson Last edited by bwilson4web; 06-10-2009 at 04:59 AM. |
| The Following User Says Thank You to bwilson4web For This Useful Post: | dave77 (08-19-2009) |
My Car: 2005 Prius Model: Package: Thanks: 3
Friends: 9 | this is great but to me not new. i see that when in this enhanced EV mode a virtual SOC of 74% or for the prius a 100%(real74%) full battery and between the `( )` the real SOC. so to me this is the same hymotion and norm with the BMS± is doing fake the SOC so the prius thinks it needs to get some more energy out of the battery pack because its getting to full and wants to protect the battery. i can drive 100kmph without using the ice because of this with the BMSplus and have been doing this for several months now.
__________________ Member off the SuperWhite Prius club 2.9L/100km - EU - tire's 51 PSI seat belt beeper remedy = buckle up Safety first... Say NO to DLRlights Last edited by Flying White Dutchman; 06-10-2009 at 05:51 AM. |
| The Following User Says Thank You to Flying White Dutchman For This Useful Post: | dave77 (08-19-2009) |
Friends: 0 | Bob, correct. But this is for steady cruising only, another question is acceleration up to that max. speed point, and there comes the limit of ~50kW MG2 motor and the battery/bms system involved. Obviously, the more agressive aero&weight mods performed to stock Prius the better accel. & cruising economy combined in the end.. But the best kick from this kit is the above 52mph smooth switching between all those PHEV/EV modes.. Last edited by Mesuge; 06-10-2009 at 07:47 AM. |
| Member Join Date: May 2009 Location: Indianapolis
My Car: 2007 Prius Model: N/A Package: #3 Thanks: 12
Friends: 0 | Is this a good idea? I thought a safety was put in because if you were past 60MPH or so and let up on the gas, engaging regenerative breaking, it would spin too fast for the motors. -->Adam |
| The Following User Says Thank You to alevinemi For This Useful Post: | dave77 (08-19-2009) |
| Senior Member Join Date: Aug 2008 Location: Phoenix, AZ
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 0
Friends: 1 | Furthermore, and someone chime in here to correct me, but I believe the HSD is lubricated from an oil pump driven off the ICE. If the ICE is still, there is no lubrication of the HSD and driving at 75MPH in such a mode would create undue stress/wear. |
| The Following User Says Thank You to EZW1 For This Useful Post: | dave77 (08-19-2009) |
Friends: 37 | I'd sure like to know what the inverter temps were and MG1 rpm with that sustained 100-130 amp draw at those speeds. While I share the excitement that this can be achieved, I don't think it's a good idea. |
| The Following User Says Thank You to efusco For This Useful Post: | dave77 (08-19-2009) |
Friends: 22 | With the Hymotion battery if you draw anything over 30A the stock battery will start to lose its SOC. When that happens the Hymotion battery starts to lower the fake SOC. If the stock battery SOC gets to low the fake SOC gets to low and the car starts to go back to lower than 70MPG in blended mode. If I were to do what Chris did with my Hymotion battery I think I would damage both batteries pretty quick. They must be using a different method or replacing the stock battery with a custom one so they can draw 100+A like that without problems. Does anyone know what they are doing exactly?
| The Following User Says Thank You to TheForce For This Useful Post: | dave77 (08-19-2009) |
Friends: 9 | is the hymotion using a dc/dc converter or higher voltage addpack to charge the oempack and provide extra energy to the prius ev system. looking that the voltage also went up when using the enhanced ev mode in that video i think its a bigger and better chemistry battery pack with a dc/dc converter and bigger wire´s then there is no problem the hymotion pack is not that big in kwh. |
| mode, mph |
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/63124-70-mph-electric-vehicle-only-mode.html | ||||
| Journal - Aminorjourney | This thread | Refback | 06-12-2009 07:14 PM | |
| "Doggie in the car Mode"-- READY Mode, AC On & Remotely Lock doors? | bob749prius | Gen II Prius Technical Discussion | 19 | 08-30-2009 08:18 AM |
| IG-On Mode | Marvinh | Gen II Prius Main Forum | 5 | 04-26-2008 04:29 PM |
| EV mode @ 40 MPH | AndreJ | Gen II Prius Main Forum | 17 | 06-06-2007 10:19 PM |
| EV Mode Kit | PrincetonPrius | Gen II Prius Technical Discussion | 2 | 05-14-2007 11:14 AM |
| Let's re-name the EV mode. | Prius Maximus | Gen II Prius Main Forum | 12 | 12-21-2004 07:52 PM |
