This is a discussion on Enginer Switch Update within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; We made the modification to fit the way we use the system. While knowing exactly how many volts are left ...
Old 09-02-2009, 04:13 PM   #11
cabledave
cabledave's Avatar
Default Re: Enginer Switch Update
We made the modification to fit the way we use the system. While knowing exactly how many volts are left is certainly useful, however we don't want a multimeter velcro'd to the dash.
The LED wasn't serving its purpose at all and the buzzer will certainly tell us know when to turn the system off, which is all we need.
Our main goal was to make the interface look less like a 'kit'.
cabledave is offline
The Following User Says Thank You to cabledave For This Useful Post:
dave77 (09-02-2009)
Old 09-02-2009, 04:29 PM   #12
eMileage
eMileage's Avatar
Nice work on the rocker switch enhancement! Would you happen to have a link to that part as well? Does the LED on the switch light up when in the 'on' position? (couldn't really tell from the pic) Have you had a chance to test your buzzer? How do you like it? Can you hear it from it's location (behind the button?)? Does it stop buzzing when you turn off the system? Thx!
eMileage is offline
The Following User Says Thank You to eMileage For This Useful Post:
dave77 (09-02-2009)
Old 09-02-2009, 04:55 PM   #13
cabledave
cabledave's Avatar
The current switch doesn't light the LED. I have ordered two different switches to try. One of them has a 2v LED which should work. I will post here after I get one or the other to light up the LED.
Haven't had a chance to run the voltage down to 46v yet to test the buzzer. We tested the buzzer with a battery and it was plenty loud for us.
Yes it should stop buzzing after you shut the system down since it is connected in place of the red LED.
dave77 (09-03-2009)
Old 09-02-2009, 09:43 PM   #14
Dan.
MPG Centurion
Friends: 20
Couldn't quite figure out from the post, but are you able to read the Volt reading from the cockpit? A wireless Voltmeter or something?
11011011
Dan. is offline
The Following User Says Thank You to Dan. For This Useful Post:
dave77 (09-03-2009)
Old 09-03-2009, 10:29 AM   #15
krousdb
krousdb's Avatar
Model: I
11011011
Yes, I have a Voltmeter in my forward cupholder. It is wired (with an inline fuse) to the main terminals between the batteries and converters.
krousdb is offline
The Following 2 Users Say Thank You to krousdb For This Useful Post:
dave77 (09-03-2009), whk.wang (09-10-2009)
enginer, switch, update
Enginer PHEV Technical Information krousdb Prius PHEV Plug-In Modifications 159 Yesterday 01:24 AM
Has anyone installed the enginer PHEV? alevinemi Prius PHEV Plug-In Modifications 669 11-18-2009 07:29 PM
52mph/70mph EV only with Enginer... possible? Atari Prius PHEV Plug-In Modifications 5 09-20-2009 03:29 PM
Enginer PHEV DC/DC Overheating issues kiettyyyy Prius PHEV Plug-In Modifications 58 09-17-2009 08:23 AM
