This is a discussion on 2008 Article "Pimping the Prius. Nuts & Volts Magazine? within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; I just came across an article from Nuts & Volts Magazine from August 2008 titled "Hacking the Prius". The Cover ...
LinkBack (1) Thread Tools
Old 10-28-2009, 10:34 AM   1 links from elsewhere to this Post. Click to view. #1
ericbecky
ericbecky's Avatar
My Car: Other Hybrid
Friends: 45
Default 2008 Article "Pimping the Prius. Nuts & Volts Magazine?
The Cover of the magazine showed a Prius and this title
"Pimping" the Prius
Get up to 100 MPG with this hybrid hack.
In it the author, Jim Fell, added 56, 50AH Thundersky Lithium batteries to his Prius.
I tried to search PriusChat for discussion on this article but came up with nothing.
Did anyone else see this article?
ericbecky is online now
The Following 2 Users Say Thank You to ericbecky For This Useful Post:
blueumbrella (10-31-2009), dave77 (10-28-2009)
Old 11-03-2009, 12:32 AM   #2
chuckknight
Default Re: 2008 Article "Pimping the Prius. Nuts & Volts Magazine?
You've piqued my interest...did anyone else see this?
Chuck
chuckknight is offline
The Following User Says Thank You to chuckknight For This Useful Post:
dave77 (11-04-2009)
Old 11-03-2009, 08:48 AM   #3
ericbecky
ericbecky's Avatar
Friends: 45
After looking around a bit on the internet, it turns out another article contained the same info as the Nuts & Volts article.
Here's the link to the alternate article by The Institute of Engineering and Technology titled "How to Get 100mpg From Your Car" published June 6, 2008.
"As the automotive X Prize gets underway in the US, I will talk you through how to modify your own hybrid vehicle to achieve 100mpg.
The interesting thing about the Toyota Prius is that it can run for a limited period as an EV, however with the NiMh battery pack the electric motor can take the car only about one mile at less than 31mph. I wanted to reduce the fuel consumption of the Prius from 60mpg to 100mpg, a massive cost saving, by the addition of a large Li-ion pack"
The Following User Says Thank You to ericbecky For This Useful Post:
dave77 (11-04-2009)
Old 11-03-2009, 11:35 AM   #4
sub3marathonman
Yes, I have the article. It was really pretty ingenious at the time.
Jim Fell, who lives in England, used a Manzanita Micro PFC40. The PFC40 allowed him to output DC current, from a 210V Li-Ion battery pack he happened to have on hand, to one of two separate lines, a "high line" or a "low line." For the "high line" he set it to charge the NiMH Prius battery to 70%, and for the "low line" he set it at a slightly lower voltage to allow the Prius battery to go back down to 65%. He limited the current to 25 amps from the battery pack (apparently because of the condition of his battery pack, not the limit of what the PFC40 could provide). He made essentially a minicomputer to monitor the CANbus and throw a pair of high voltage power contactors depending on the SOC of the Prius battery. He was thus able to get about 100 mpg in this "battery boost mode." He talked about a future project of automatically switching the car to EV mode if it was under 30mph.
I still think the Manzanita method is interesting, but there are a couple of drawbacks I have run into. It is a bit expensive, but apparently it is of a very high quality, and I can't get the specifications. What is a real benefit though is that it will also double as the battery pack charger too, which saves the purchase of an expensive battery charger.
sub3marathonman is offline
The Following User Says Thank You to sub3marathonman For This Useful Post:
dave77 (11-04-2009)
2008 article pimping, magazine, nuts, prius, volts
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/71284-2008-article-pimping-prius-nuts-volts-magazine.html
Untitled document This thread Refback 11-07-2009 07:16 PM
Pimping out the Prius to show "I'm not gay!" Anthony Gen III 2010 Prius Main Forum 78 08-18-2009 10:19 PM
Fortune magazine article parrot_lady Prius and Hybrid News 0 02-28-2006 05:25 PM
Reverse Engineering Article in Wired Magazine SirSpidey Prius and Hybrid News 21 01-30-2006 01:29 AM
Hybrids Hed2Hed - Another Wired Magazine Article jkash Prius and Hybrid News 2 03-23-2005 11:00 AM
Magazine article Speedracer Gen II Prius Main Forum 1 07-11-2004 08:18 AM
