Plug In solution 10kWh Conversion
Old 08-02-2011, 08:03 AM   #21
Package: I-Tech
Default Re: Plug In solution 10kWh Conversion
Dont forget us aussies as well
wrexed03 is offline
Old 08-03-2011, 05:35 PM   #22
banshee08's Avatar
Model: II
Am wondering if the 4kWh kits are upgradable to say 8kwh later??
Originally Posted by kiettyyyy View Post
Hey all...
Sorry I've been on a slight hiatus on PriusChat.. I typically reply to these PIS vs Plug-In Solutions posts as I'm a Plug-in Supply engineer :P
All of the litigation issues between Plug-In Supply and Plug-In Solutions have been thrown out by the judge in Orange County. The judge also to effect stated that Plug-In Solutions should no longer make additional accusations against Plug-In Supply...
Just a quick tid bit about where I've been for so long. As a teaser, I'll post fragmented sentences.
3rd Generation Prius
New PHEV kit(4kWh for Gen2 and Gen3)
EV Mode up to 57 MPH(Gen 3)
EV Mode up to 74 MPH(Gen 2)
100+ MPG on Gen 3
Telemetrics to online site/mobile phone
Have I interested anyone? :P
banshee08 is offline
Old 08-03-2011, 06:51 PM   #23
High Fiber Member
hill's Avatar
Friends: 24
Hey all...
All of the litigation issues between Plug-In Supply and Plug-In Solutions have been thrown out by the judge in Orange County. The judge also to effect stated that Plug-In Solutions should no longer make additional accusations against. . . . . . . . . . . .snip........... :P
So. . .there is/was no 'winner' as to who's cheating anyone, or even whether anyone at all has done anything wrong to anybody? Ok, then, sorry for getting it backwards maybe. It interests me because the 15kWh usable SUV pack would be great for us ...
hill is offline
Old 08-04-2011, 12:10 PM   #24
NYPrius1's Avatar
Thumbs up Re: Plug In solution 10kWh Conversion
Originally Posted by scottsim View Post
My car...and I have had good luck with my conversion, receiving updates as available...next update expected to address 52mph EV limit, and possibly regen to the large pack...and though I use a SCANII to monitor various parameters, would be really nice to see the current StateOfCharge of the large pack.
Scott
Scott's Plug-in Pruis Blog | Converting my 2009 Pruis into a plug-in hybrid electric vehicle (PHEV)
Scott,
How will that compare with the new Prius Plug In due out in the spring?
NYPrius1 is offline
Old 08-06-2011, 02:27 PM   #25
Originally Posted by NYPrius1 View Post
Scott,
The 2012 PHEV Prius will have less EV range (smaller large pack), less mixed-mode range...most likely more highly engineered and backed by the maker...bottom line, at least for me: Too little, too late.
scottsim is offline
Old 01-25-2012, 03:55 AM   #26
Good questions over here not being answered:
Why is the speed limit on the prius III EV 57 MPH and the prius II 74 MPH?
z704w40 is offline
Old 01-25-2012, 04:23 AM   #27
cproaudio's Avatar
Model: V
Package: Adv. Technology
The pack is not upgradeable. Once you get the 4KW kit, you're stuck with 4KW kit. There's no 8KW kit. The 4KW kit uses headway's 40160s 16ah cell. The 10KW kit uses 40ah cells. You would have to find 32ah cells in order to get 8KW.
I think you mean the speed difference between Gen II and Gen III and not Prius II and Prius III. I personally prefer the low speed EV over high speed EV because at high speed EV, you need some serious current to sustain the high speed. The battery will drain quickly. At lower speed, the electric motor won't pull as much current so your battery pack retains its charge longer.
cproaudio is offline
Thanked by:
dave77 (01-25-2012)
10kwh, conversion, plug, solution
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/95541-plug-in-solution-10kwh-conversion.html
Thread Plug In solution 10kWh Conversion | PriusChat Forums | BoardReader This thread Refback 03-31-2012 02:42 PM
Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader This thread Refback 01-28-2012 10:52 AM
Thread 2004 Prius with 10KwH Plug-in conversion | PriusChat Forums | BoardReader This thread Refback 12-12-2011 11:07 PM
plug-in supply conversion battery | BoardReader This thread Refback 11-01-2011 04:11 PM
Plug In Prius Conversion This thread Refback 07-13-2011 05:47 PM
Plug In solution 10kWh Conversion - PriusChat Forums This thread Refback 06-29-2011 12:08 PM
10KWh conversion discharge at rest. scottsim Prius PHEV Plug-In Modifications 4 05-12-2011 10:07 AM
Plug-in conversion yet ? jstack Local Prius Club Main Forum 45 12-31-2009 02:06 PM
Help! Code 293 after plug-in conversion EVron Gen II Prius Technical Discussion 6 12-11-2009 12:56 PM
My Sirius Plug & Play solution BassMasterK Gen II Prius Audio and Electronics 40 11-06-2006 06:22 PM
Plug in conversion findlj Gen II Prius Technical Discussion 6 10-18-2006 02:33 AM
