| Prius Technical Discussion This is a discussion on Using the Brake within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I'm curious about the braking system on my prius. Does regeneration occur steadily throughout the entire braking operation, or does ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm curious about the braking system on my prius. Does regeneration occur steadily throughout the entire braking operation, or does it vary according to the pressure applied to the pedal? How can you capitalize by altering your own braking habits? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | There are numerous threads on the subject. Use "search". . Both regeneration and physical braking are applied over a smooth continuum whose parameters are dictated by many inputs. You can definitely learn to play this for best results. . _H* |
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi Montego, We have been having this discussion on PriusOnline. Check out http://www.priusonline.com/viewtopic.php?t...bd5c533fe16695b . For short, using Attila's data at http://www.vassfamily.net/ToyotaPrius/CAN/eveffindex it seems that about 81.5 percent of the motion energy is regenerated into the battery. And about 66.6 percent of battery energy gets converted into energy of motion for an acceleration. So, this works out to 54.3 percent times the battery losses. A lowball value for the battery efficiency is about 85 percent (I read someplace that 90 percent is more typical), and at that value a conservative total efficiency of reuse estimate is then about 46 percent. This is only one data point (from and to 50 km/hr - 31 mph) however. Actual driving conditions will be more variable. The amount of energy regenerated is variable too. Check out http://www.vassfamily.net/ToyotaPrius/CAN/brindex.html for more details. |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(donee @ Jun 27 2006, 10:06 PM) [snapback]277900[/snapback]</div> Quote:
| Senior Member Join Date: Feb 2004
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Daniel I'm really in the dark on this subject. From your post it seems like your experience with CAN is that just letting off the gas gives a little re-gen. Then I think I get from your post the harder you brake the more re-gen you get. Question: do they combine? That is is 1+2=3? or does 2 cancel out 1 thereby=2? Next question is how does selecting B fit into the equasion according to CAN? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(daniel @ Jul 2 2006, 08:26 AM) [snapback]280079[/snapback]</div> Quote:
///d@ | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(MarinJohn @ Jul 2 2006, 11:40 AM) [snapback]280100[/snapback]</div> Quote:
B mode shifts the engine into a high drag mode for engine braking, like downshifting for a big downhill. The rest of the braking system still works the same. Tom
__________________ Black 2006 package #7 Northern Michigan | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Regenning at very high currents is also likely to cause more ohmic heating in the battery and wiring, thus more loss. Parts get warmer, resistance increases, more and more losses. . _H* |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | John: Sorry. I don't often open the Tech Discussion forum. But I agree with all three of the replies above. I have seen it go just over 100 amps, but I think it likely, as Dithermaster says, that the actual max probably depends on various factors, including battery temp. A lot seems to depend on battery temp. I don't generally stomp on the brakes. As hobbit says, it's probably less efficient. But I'm not a high-mpg guru either. And I've had my share of sudden stops. Doing 45 on a main drag and a light turns yellow just as you're close upon it, and it can take a 100-amp deceleration to stop. I'd rather waste a wee bit of energy than go through a yellow light if I can safely stop. Safety first. Then conservation.
__________________ Daniel ---------------------- Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.) "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck |
| ABS brake warning on 2007 Prius leading to brake failure | adk235 | Care, Maintenance and Troubleshooting | 4 | 08-05-2008 07:02 PM |
| Brake job | silfey | Prius Technical Discussion | 26 | 05-22-2008 03:36 PM |
| Emergency Brake | andyprius | Prius Main Forum | 11 | 05-04-2007 08:30 PM |
| Brake pad replacement | pafoss | Prius Main Forum | 13 | 05-14-2006 11:19 AM |
| What exactly happens when you brake? | jamarimutt | Prius Main Forum | 24 | 09-01-2004 06:50 PM |
