| Prius Technical Discussion This is a discussion on Steering squeaking within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I have a 2001 Prius. Runs fine overall, but has an occasional squeaking noise that seems to come from around ... |
| Junior Member Join Date: May 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have a 2001 Prius. Runs fine overall, but has an occasional squeaking noise that seems to come from around the steering column. It's a fairly low sound, almost like the sound cartoons would have for an extra-large rubber band being stretched. It's not continuous; I can't say for sure, but it seems to be maybe slightly more often present when I've been running in electric-only mode a lot. Anyway, I had it in at the dealer. Best they could come up with was "we think it's coming from the steering rack", but that it's nothing to worry about. So, I wanted to tap the collective wisdom here. Any thoughts? It's merely annoying, and only intermittently at that. |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | my 2001 prius is making the same noise, its annoying, and mine started out like yours, occasioanlly get the noise, now it happens all the time when i make turns at low speeds, i also have another 2001 prius i bought salvage with higher mileage then the one i presently drive and i beileive that had a power steering recall, and on the other prius no noise at all.. im about to ttake it to the dealer for htis issue <div class='quotetop'>QUOTE(abeagler @ Sep 28 2006, 08:48 PM) [snapback]325335[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(statultra @ Sep 30 2006, 11:15 PM) [snapback]326321[/snapback]</div> Quote:
It actually seems a little worse since it came back from the dealer than it was for months before. Hmmm. The only thing they tried was replacing a boot on the steering column they said had a tear, but that did nothing. Colin | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Further update - their best guess was that the steering rack would need replaced to get rid of the noise; however, they couldn't tell me why that would help, nor what they thought the actual problem was. Noise is still worse since back from the dealer, though, including a creaking noise on harder acceleration from stops. |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | get some WD-40 and squirt a couple jets under that boot. if it's anything like the camry/avalon problem that sounds very much like what you describe, there should be a round boot with a big clamp around it and the steering shaft coming through. squirt some WD-40 in there and see if it decreases the noise. DH can take a look at one tomorrow more closely. |
| Door sill - squeaking? | BethlehemPrius | Care, Maintenance and Troubleshooting | 2 | 06-13-2007 06:36 AM |
| Loose Steering?? | CIA_Guy | Care, Maintenance and Troubleshooting | 2 | 05-02-2007 02:36 AM |
| Steering | jared2 | Prius Main Forum | 3 | 03-20-2006 02:46 PM |
| Rear hatch squeaking | ltu1542hvy | Prius Main Forum | 23 | 07-03-2005 02:16 PM |
| steering | tofani | Prius Main Forum | 1 | 09-03-2004 03:37 PM |
