Prius Technical Discussion This is a discussion on OBD Plug within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I can't find the OBD plug on my 2005 Prius. On all my other cars it was located on the ...
Old 12-08-2006, 07:37 AM   #1
buzzard bill
I can't find the OBD plug on my 2005 Prius. On all my other cars it was located on the bottom of the steering colum. I want to hook up a scangauge. Can the scangauge be hooked up to run continuously?
Thanks,
Bill
buzzard bill is offline
Old 12-08-2006, 08:17 AM   #2
Georgerl
<div class='quotetop'>QUOTE(buzzard bill @ Dec 8 2006, 07:37 AM) [snapback]359233[/snapback]</div>
Thanks,
Bill
I believe it is the same place as my '06, between the steering collumn and the display console just back of where the dash wraps under.
Yes you can leave the Scangauge plugged in all the time, mine is on my Prius and my F250 4X4. Be sure to set the scangauge engine to 'hybrid' or it wil shut off when the engine shuts off. The scangauge will power itself down a few seconds after you shut off the car.
Works great, can hardly wait 'til the USB mod is available for the scangauge to enable other hybrid items to be displayed.
Good Luck!
Tigerman
My "FAST" car is a Sunbeam Tiger!
Georgerl is offline
Old 12-08-2006, 01:27 PM   #3
hobbit
hobbit's Avatar
If you're sitting in the seat with your foot near the accelerator,
the plug is over your right shin. Which gets in the way a little
bit if you're driving around with an OBDII dongle in there! ...
_H*
hobbit is offline
Old 12-09-2006, 07:15 AM   #4
buzzard bill
Thanks for the information.
Bill
Plug it in! PriusTouring07 Prius Main Forum 10 07-18-2007 05:16 PM
Plug it in Somechic Prius Main Forum 9 11-17-2006 02:09 AM
Calif PG&E To Harness People Power To Help Bring Plug-In Hybrids To Help Bring Plug-In Hybrids to the Public hb06 Prius and Hybrid News 0 10-16-2006 02:22 PM
Where is our Plug-in Mod? 240sxer Prius Modifications 1 08-31-2006 03:34 AM
12v plug agile pagile Audio and Electronics 3 04-20-2005 04:10 PM
