Prius Technical Discussion This is a discussion on 2001 (classic) starting problem within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Before I buy a new 12Volt battery as a test, I'd like to see if anyone has had this issue. ...
Old 03-07-2007, 06:00 PM   #1
walkinghat
walkinghat's Avatar
Send a message via Yahoo to walkinghat
The car occasionallyy when cold will make a clicking sound not unlike a solenoid will click in a conventional vehicle when the battery is dead. The sound is fromn the front end when the ignition is turned to start. There are no panel lights at this point. Stop, remove key and retry and it will work on the 2'nd or 3'rd try.
My theory is a weak 12V battery? Does that battery have to power up a solenoid of any particular amperage to engage computer or the traction battery?
It has a spanking new traction battery from Toyota warranty at 113K a year ago, the 12Volt is original.
Coincidentally we have also had the issue where you have to override the gear handle with the manual button under the stearing column. To put it back in park before it will start.
Thanks
walkinghat is offline
Old 03-07-2007, 09:51 PM   #2
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 7
Wait, *which* Prius do you have? 01 or 07 or both
Probably the classic just needs a new 12 volt. I have not heard of the contacts getting dirty on the shift lever contacts but no reason why that could not happen. Do me a favor, just slide it though all its settings about 20 times when nobody is looking. Else they might laugh.
Do you know how to check your '12 volt' battery with the secret display screen?
tochatihu is offline
Old 03-08-2007, 06:15 AM   #3
walkinghat
walkinghat's Avatar
<div class='quotetop'>QUOTE(tochatihu @ Mar 7 2007, 09:51 PM) [snapback]402012[/snapback]</div>
We have one of each 01 and 07 (135K and 2K).
NO! I've not heard of the secret display screen, searched the forum didn't find it yet. It must be secret!
Thanks!
Old 03-08-2007, 08:57 AM   #4
bwilson4web
bwilson4web's Avatar
My Car: 2003 Prius
Package: #1
Nominated 2 Times in 2 Posts
Friends: 7
<div class='quotetop'>QUOTE(walkinghat @ Mar 7 2007, 05:00 PM) [snapback]401919[/snapback]</div>
Coincidentally we have also had the issue where you have to override the gear handle with the manual button under the stearing column. To put it back in park before it will start. [/b]
Everything you describe is consistent with a weak 12 VDC. Most autoshops will test the battery for no charge.
As for replacement batteries, Toyota prices are a little steep. There are Miata battery kits that can cut the price in half. Some of us are also looking at and testing batteries designed originally for motorcycles and utility vehicles that are in the $25-35 range.
bwilson4web is offline
Starting Problem davidtoo Care, Maintenance and Troubleshooting 3 12-04-2006 09:38 PM
Problem With Starting Prius TwelveInchPrius Fred's House of Pancakes 4 06-16-2006 05:22 AM
Possible Starting Problem alcor Prius Main Forum 11 06-06-2005 10:05 PM
Starting Problem blue2004Milpitas Care, Maintenance and Troubleshooting 7 05-19-2005 01:35 PM
Starting Problem 0 emissions Toyota Prius Service Bulletins - TSBs 0 12-31-1969 07:00 PM
