| Prius Technical Discussion This is a discussion on Do I Have an Issue? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi to all, I have noticed that sometimes the whole car shakes when the ICE shuts off. Sometimes when it ... |
| Senior Member Join Date: Apr 2007 Location: Wakefield, MA.
My Car: 2007 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Hi to all, I have noticed that sometimes the whole car shakes when the ICE shuts off. Sometimes when it is running while in P it seems to jump. At first I thought maybe it's me or just my unfamiliarity with the car, but our 2003 does not seem to do that. When it is in gears it is fine. It has under 3000 miles and is 3 months old. I'm open to suggestions. Wanted to run it by you experts before I call my salesman - who has been excellent for my last 4 cars BTW. And I still love it though and wouldn't want to have to part with it. Thanks for any ideas you can give me. Denise
__________________ Neicy 2007 Silver Metallic Touring Pkg #2 priuschat.com decal F52/R50 Front Side Window Deflectors Touring Emblem from Avalon Partial Grill Block EBH Repaired 4/06/08 by hobbit 2 Scangauge IIs v 3.15 with X-gauge |
My Car: 2004 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Neicy @ May 9 2007, 02:49 PM) [snapback]438569[/snapback]</div> Quote:
| Senior Member Join Date: Feb 2006
My Car: 2004 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Normal; don't worry. Sometimes more pronounced/noticeable than others, depending probably on exactly what position a piston was in when the ICE turned off. |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Normal. It does not go away with time, but you get used to it. I speculate that it's because it's the only car you've ever had (the only car most of us have ever had) that shuts off its engine whenever it feels like it. As much as you learn that this is what it does, you're never quite ready for it when it does. By comparison, on other cars, the engine only shuts off when you turn off the ignition. Because it is your explicit action, you know the exact moment it's going to happen, and the shudder is not as startling. It can be a bit annoying. I actually find it most annoying when it takes longer to shut off than I think it should. The solution is an electric car. Then you have no engine. Just an electric motor that is never going unless the car is moving.
__________________ Daniel ---------------------- Primary car: Zap Xebra SD: 100% electric car. 1.9 cents per mile, using electrons generated from water power. (The Prius is my gas guzzler, used when I have to travel farther than 35 miles in a day.) "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(qbee42 @ May 9 2007, 06:15 PM) [snapback]438721[/snapback]</div> Quote:
Dave M. | |
| Senior Member Join Date: Mar 2007 Location: New England
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 2 | My car also show the symptom as you listed. Mostly happen when I powered up the car and the ICE start the warmup process. The car jump a bit. Car also jerk/shake when the ICE shutting down while travelling on the road. I would suggest to take it to the toyota dealer and have a mechanic check on it. It might have a defective part such as engine mount. For my situation, I will continue to monitor the car. If the symptoms is getting bad, I'll have the car checkup. p.s. toyota will not issue a TSB unless more owners complaint.
__________________ 2007 Prius - Classic Silver Metallic Current Mod : BT Tech Stiffening Plate and Strut Brace, SGII, Huper Optik Tint, Stubby Antenna, Block heater, EV mod, Bazooka BTA8100, PIAA 500/600 Hz Horn. Accessories: OE All Weather Mat, OE Wheel lock, OE Mud Flap, OE Cargo Net, Thule Roof Rack. Free Mod : Disable backup beeper, Disable Seatbelt beeper, Removed wheel cover. I'm folding for Team PriusChat. |
| Senior Member Join Date: Jan 2006 Location: Somerville, MA
My Car: 2006 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | As others have said, during the warm-up period (~ first 5 minutes) the ICE will shut down roughly. I'm not sure why that is. You will also have a tough time stealthing while in this "state". Once the car has warmed up (seem to happen faster if you are able to go >35mph at sometime during the 1st five minutes) the car will shut down the ICE smoothy and you can now get into stealth mode easier. You can also get back into "shudder" mode if the cars cools down to much. This happens to me on my commute as I can pulse/glide quite a bit. If I notice that at a stop the car "shudders" when shutting down (again) I know it will need to use the ICE for some time to heat up again. To accomodate this I don't try to glide as much for a few minutes. So I use this shudder to tell me in what state the car is in. |
My Car: 2007 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | <div class='quotetop'>QUOTE(SomervillePrius @ May 10 2007, 11:21 AM) [snapback]439104[/snapback]</div> Quote:
Thanks. As most have said it is when I first start it after it has been sitting a while. Good to know others have experienced it. Was having flashbacks of times when my older cars would deisel when you turned off the key. I appreciate the replies. | |
My Car: 2004 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(SomervillePrius @ May 10 2007, 08:21 AM) [snapback]439104[/snapback]</div> Quote:
| Uh Oh... MFD issue or not? | Tideland Prius | Care, Maintenance and Troubleshooting | 5 | 02-14-2007 10:55 PM |
| SKS issue | glarnerman | Care, Maintenance and Troubleshooting | 8 | 06-09-2006 03:35 PM |
| Issue with the IRS | tleonhar | Prius Main Forum | 6 | 03-19-2006 11:26 AM |
| A/C issue | dsunman | Prius Main Forum | 17 | 02-07-2006 06:11 PM |
| Ok I have ONE more issue | tracysbeans | Prius Main Forum | 86 | 12-31-2005 08:02 AM |
