Prius Technical Discussion This is a discussion on Looks like Inverter problems within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; My 04 Prius spits and error after I have driven it for a while on a warmer day. I get ...
Old 07-04-2007, 04:57 PM   #1
psycho_pete
Question
I get a Triangle warning light, engine check light, (little circle in parenthesis) and a VSC error indicator.
I took it into the dealer and had a scan done on it - they said it looked like an inverter\heat malfunction.
I will probably just replace the entire inverter assembly but I noticed in the service manual it says that you should replace the "PCU box" along with the inverter as a pair.
Does anyone know what the PCU box is or were it's located?
Thanks in advance,
psycho_pete is offline
Old 07-04-2007, 05:54 PM   #2
statultra
uber-Senior Member
statultra's Avatar
Send a message via AIM to statultra
u should try a inverter coolant change see if helps to remedy the issue
statultra is offline
Old 07-04-2007, 05:59 PM   #3
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Nominated 3 Times in 2 Posts
Friends: 6
Shouldn't this be covered under warranty?
Godiva is offline
Old 07-04-2007, 06:13 PM   #4
psycho_pete
<div class='quotetop'>QUOTE(statultra @ Jul 4 2007, 02:54 PM) [snapback]473136[/snapback]</div>
brand new and I blead the air out also.
<div class='quotetop'>QUOTE(Godiva @ Jul 4 2007, 02:59 PM) [snapback]473137[/snapback]</div>
Salvage car
Old 07-04-2007, 06:56 PM   #5
statultra
uber-Senior Member
statultra's Avatar
sometimes there more air inside the system run the pump and shut it off and bleed it out, keep trying i got the same issue with two of my prius's 05 and a 01 .
Old 07-04-2007, 07:29 PM   #6
psycho_pete
<div class='quotetop'>QUOTE(Crumple Zone @ Jul 4 2007, 03:13 PM) [snapback]473146[/snapback]</div>
Salvage car
Is there a way I can run the pump without driving the car around?
At what location did you get more air out, the radiator or the valve at the end of the hose going to the electric motor?
Thanks again,
Old 07-04-2007, 09:19 PM   #7
FL_Prius_Driver
FL_Prius_Driver's Avatar
My Car: 2001 Prius
Did you get from the dealer what DTC's were coming out?
Certainly don't want you to experience the frustration of replacing an inverter and find out it is an inverter cooling problem.
FL_Prius_Driver is offline
Old 07-04-2007, 10:08 PM   #8
psycho_pete
<div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 4 2007, 06:19 PM) [snapback]473230[/snapback]</div>
I asked for the DTC's but all they told me was that it looked like the inverter was overheating.
I will take it back tomorrow and have them rescan like they were supposed too.
Old 07-05-2007, 09:55 AM   #9
Mr.Vanvandenburg
Salvaged cars are included in the emission control warranty, according to the manual. In CA states it is 15/150 if I remember right. The inverter is one of the covered items. Of course if the inverter was previously damaged in an accident then that would make them question. Good luck.
Mr.Vanvandenburg is offline
Old 07-05-2007, 05:42 PM   #10
FL_Prius_Driver
My Car: 2001 Prius
When hobbit was doing an inverter examination (http://techno-fandom.org/~hobbit/cars/ginv/), one thing he noticed was some gunk in the inverter cooling channels. Take a look yourself at his work. If your dealer is claiming an inverter cooling problem, then there should be some way to see what the flow is. The rest is physics and "physics" is not broken. Take a picture to the dealer of hobbits inverter picture (assuming he did this to help people like you). Ask "Anyway to remove crud like this?" can only lure the dealer into getting the smart technician involved. You want the smart technician.
I may be wrong, but the flow should be measurable if the car is running. Looking at the NHW11 service manual, there is a water temperature switch that closes between 118 to 131 F. It looks like this temp switch turns on the radiator fans. The rest of the design is a pump and a radiator.
If nothing else, make sure the radiator fans work and that the inverter cooling fluid flows.
Inverter gone bad... tr_blankenship Care, Maintenance and Troubleshooting 11 10-20-2008 10:43 PM
Inverter teardown! hobbit Prius Technical Discussion 12 07-10-2007 08:51 PM
Power Inverter Sillyboy Audio and Electronics 6 04-11-2007 09:23 PM
Inverter on sale. Godiva Prius Main Forum 3 03-25-2007 08:41 PM
?s re: checking oil and inverter bfh Care, Maintenance and Troubleshooting 2 01-02-2005 04:15 PM
