| Prius Technical Discussion This is a discussion on Beeping when using Smart Key for unlocking within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(mgipe @ Aug 24 2007, 06:10 PM) [snapback]501792[/snapback]</div> Mainly, that's the way Toyota designed it. The inside button locks ... |
| | #11 | |
| Just another Onionhead Join Date: Mar 2007 Location: Texas
My Car: 2007 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(mgipe @ Aug 24 2007, 06:10 PM) [snapback]501792[/snapback]</div> Quote:
I don't consistently use one method or the other, though I prefer the immediacy and tactile feel of the inside button more. But the safeguards provided by the outside button are well worth it. | |
| | #12 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(zenMachine @ Aug 25 2007, 12:22 AM) [snapback]501890[/snapback]</div> Quote:
For the OP, I want to point out that unlocking by grabbing a door handle only works with the front doors and the hatch. The default behavior is to unlock all of the doors when unlocking by the passenger door or hatch, and only the driver's door when touching that handle. You can change this behavior by doing a little setup with the key fob. It's spelled out in the manual and also on this site. Another subtle point is that the unlockers on the front doors are touch sensitive, while the one on the hatch is pressure sensitive. When you unlock with either of the front doors, all you have to do is touch the inside of the handle and the car will unlock. With the rear hatch, you have to apply some pressure and wait for a short interval before it unlocks. This prevents rain and wind turbulence from messing with the rear hatch control. With the SKS, sometimes you will notice the door locks cycling when you wash your car. This is from water tripping the touch sensors on the front door handles. Either ignore it, or temporarily turn off the SKS system by pushing the button under the steering wheel. Tom
__________________ Black 2006 package #7 Northern Michigan | |
| Smart Key System Not Beeping | trenapt | Prius Technical Discussion | 1 | 07-21-2007 12:54 AM |
| Unlocking with fob | glscheil1 | Audio and Electronics | 14 | 07-12-2007 07:38 PM |
| Central unlocking | micaela | Audio and Electronics | 1 | 07-12-2006 10:26 PM |
| Unlocking 4 doors in '06 | krainium | Prius Main Forum | 10 | 05-26-2006 08:38 PM |
| Unlocking all doors with SKS (Was: Deleted) | tracysbeans | Prius Main Forum | 73 | 01-22-2006 03:15 PM |
