| Prius Technical Discussion This is a discussion on Battery Vent within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I started my car up today and about a minute into my drive I heard a noise coming from my ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I started my car up today and about a minute into my drive I heard a noise coming from my passenger side rear battery vent. At first, I thought i had the window cracked, but I didn't. So I turned my music down and when I still heard it, I got nervous. After a couple more minutes of driving the sound stopped. I don't know if I've overlooked this in the manual or haven't researched enough, but does anyone have any ideas? Is this normal??? |
| Platinum Member Join Date: Jul 2004 Location: Sacramento
My Car: 2005 Prius Package: #4 Nominated 15 Times in 1 Post TOTM Awards: 1Friends: 0 | Just how hot was it in Herndon, VA? Was the car parked in the sun with the windows up? Had you driven the car earlier - where the traction battery could still have residual heat? Did you crank-up the air conditioner when you drove away? Any one, or a combination of the above could help explain the traction battery cooling fan coming on and going off within a few minutes . . . but exactly what did this "noise' sound like? |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | People need to be more specific when they post about noises. What sort of noise? Did it sound like a chipmunk, or Jimmy Hoffa locked under your cargo area? We may be good, but we're not clairvoyant. Tom |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 28 2007, 03:06 AM) [snapback]503126[/snapback]</div> Quote:
The noise sounded like the AC system except coming from the battery vent. So the fan theory sounds like it would make sense to me. I had just never heard of it switching on before. And yes, the car was parked in the sun, and the AC was on as I drove off. But I had driven the car in those circumstances at least 1 million times this summer, but had never heard the noise. | |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | The battery vent doesn't turn on very often.. but that was it. it's odd hearing it the first several times. i found it exciting. my passengers didn't hear it. they figured it was outside noise or normal vent noise. I knew it was the fan. If you start the car and climb a hill, it turns on. |
| Senior Member Join Date: May 2006 Location: Cincinnati, OH
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(V8Cobrakid @ Aug 28 2007, 12:28 PM) [snapback]503254[/snapback]</div> Quote:
| Member Join Date: Jun 2007
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(rudiger @ Aug 28 2007, 09:36 AM) [snapback]503259[/snapback]</div> Quote:
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | <div class='quotetop'>QUOTE(mgipe @ Aug 28 2007, 01:40 PM) [snapback]503291[/snapback]</div> Quote:
Paris Hilton locked under the cargo area: " ..." (she stops making noise when you cover her) Tom | |
| I Need to Vent | Prinux | Prius Main Forum | 16 | 09-27-2007 01:05 PM |
| battery vent, back seat | hmerskine | Prius Main Forum | 3 | 02-11-2007 01:22 PM |
| Battery Vent | Maytrix | Care, Maintenance and Troubleshooting | 1 | 07-29-2006 05:25 PM |
| Battery Vent Hiss | vhmarx | Care, Maintenance and Troubleshooting | 9 | 05-07-2006 09:22 PM |
| How to prevent things from dropping into the battery vent? | priusist | Care, Maintenance and Troubleshooting | 4 | 01-07-2005 02:21 PM |
