| Prius Technical Discussion This is a discussion on auto-charge procedure? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(KMO @ Aug 29 2007, 11:27 AM) [snapback]503835[/snapback]</div> And this is a problem? Are you saying it can't maintain ... |
| | #11 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(KMO @ Aug 29 2007, 11:27 AM) [snapback]503835[/snapback]</div> Quote:
| | #12 | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(Display Name @ Aug 29 2007, 02:44 PM) [snapback]503913[/snapback]</div> Quote:
1) Google map showing the segment 2) Topozone map of the same segment All of my data indicates you should be OK up to 60 mph. We really need to understand the scenario including what happens before reaching the base of the hill. Also, is this just one hill or do other hills present the same problem. Thanks, Bob Wilson ps. On the Google map, use the point-to-point driving option to get a route segment that includes the hill. It doesn't have to include any sensitive data such as home or work locations. You can use the 'handles' in Google to make and even mark the start and stop of the hill. Google maps can give you a valid URL that we can use to bring up the same map or post it as a link in your reply. pps. Topozone is a little trickier. Navigate to the area and move the center point until it is in the middle of the hill. Then adjust the scale until you get something that overlaps the Google map. Topozone will also give you a cut-and-paste URL that we can use. | |
| | #13 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(Display Name @ Aug 29 2007, 03:44 PM) [snapback]503913[/snapback]</div> Quote:
Tom | |
| | #14 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(qbee42 @ Aug 29 2007, 03:17 PM) [snapback]503967[/snapback]</div> Quote:
Bob, I'm sorry but I don't wish to go to that much effort (to be honest) but if you're interested, you can map those towns I've mentioned. I've re-edited this post a couple times - forgot to add requested info. Yes, type of hill, or perhaps "sequence of inclines" does seem to matter. If I'm driving for 10 miles up a gentle incline, say 3% then hit something steep, like 6% or more, the car will continuously lose battery. If I drive, say, 5 mph over the limit, the same route can put the battery drain over the edge and the car will come to that crawl. If this happens on a steep incline, the car will not go over 30 mph. If you don't live in an area where you ascend and descend 3000-5000 ft on a trip, you may never experience this. Since we camp and fish a lot, we go into the foothills frequently so I've noticed this problem. Of course, coming down these slopes means my battery goes to a full charge very quickly. Found this link to other people with the same problem: http://priuschat.com/Lost-all-Power-going-...ses-t36757.html Also remembered this didn't seem to happen in the winter, and I'm wondering if a warm/hot battery simply discharges slower... | |
| | #16 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(Display Name @ Aug 30 2007, 12:41 PM) [snapback]504346[/snapback]</div> Quote:
Tom | |
| | #17 | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 7 | <div class='quotetop'>QUOTE(Display Name @ Aug 30 2007, 11:41 AM) [snapback]504346[/snapback]</div> Quote:
55 mph - works all the way to the top of any 6% grade 60 mph - probably works OK 65 mph - will run out of battery 65+ mph - will run out pretty quickly AC is a problem so too is any additional weight. So my thinking is use to same speed as a heavy, semi-trailer going up a grade and you'll be good to go. Go faster and there will be disappointment. Bob Wilson | |
| | #18 | ||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Fred S @ Aug 30 2007, 11:52 AM) [snapback]504394[/snapback]</div> Quote:
behind a cement truck or something and have to drive extremely slow the battery also lasts longer. <div class='quotetop'>QUOTE(bwilson4web @ Aug 30 2007, 04:05 PM) [snapback]504533[/snapback]</div> Quote:
Take a look in google earth at the route from Golden, Colorado, US to Georgetown, Colorado, US on I70. | ||
| charging procedure for 12 volt battery | priusunum | Prius Technical Discussion | 22 | 06-14-2007 02:42 PM |
| Antenna removal procedure | Wendel | Prius Main Forum | 7 | 01-31-2006 01:56 PM |
| Transport Canada's Testing Procedure | Tideland Prius | Fuel Economy | 0 | 01-16-2006 02:22 PM |
| AIC-100i firmware update procedure? | jwdberlin | Audio and Electronics | 6 | 11-11-2005 11:33 AM |
| Two forum procedure questions ... | Ken Cooper | PriusChat Website Questions | 3 | 03-16-2004 10:10 AM |
