| Prius Technical Discussion This is a discussion on auto-charge procedure? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Someone had mentioned a sequence of gas pedal depressing, power-on, maybe odometer button pressing, that would instruct the vehicle to ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Someone had mentioned a sequence of gas pedal depressing, power-on, maybe odometer button pressing, that would instruct the vehicle to charge until "full". I cannot find any of that discussion no matter how hard I look on Priuschat or elsewhere. Can someone point me to that or simply repost? Much appreciated! |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 20 | It's called force charging. Put the car in D, push the brake firmly and press the accelerator to the floor and keep it there until it won't charge any more. Please realize that there are really not very many good reasons to do this...it's very inefficient energy wise. If you're going to be in an MPG challenge it's helpful to start with a full battery for a few extra feet of distance on electric only. If you're going to be storing the car for a very extended period (3-6 months?) then it would probably be smart to have it as fully charged as possible. Other than that there are no advantages in daily driving. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Aug 28 2007, 12:13 PM) [snapback]503303[/snapback]</div> Quote:
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 20 | <div class='quotetop'>QUOTE(Display Name @ Aug 28 2007, 02:13 PM) [snapback]503343[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(efusco @ Aug 28 2007, 01:17 PM) [snapback]503346[/snapback]</div> Quote:
I actually run out of battery frequently. The result is an extremely sluggish car that works hard to maintain 30mph uphill. It makes sense really. Since the car draws off and charges the battery on long steep hills the same as it would on flat ground. There is horsepower to spare obviously because the engine isn't revving to compensate for the uphill load until *after* it runs out of battery. | |
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 5 | Climbing a 6% grade, if you'll keep your speed below 65 mph and 55 mph is perfect, you'll not have any significant battery drain. As your speed reaches 65 and above, the battery drain becomes pretty ugly. My trick is to follow a heavy truck up the truck climb lane. They are usually running at a perfect speed. As for when a 'force charge' makes sense, let us say you have a reporter or hybrid skeptic you want to let drive your car. About half and hour before the meeting, do a 'force charge.' Then let them drive the car. Sure the mileage will look even better than normal but that is just to compensate for them driving it badly. <grins> I also use this technique when testing quarter mile acceleration or when sitting next to a particularly obnoxious, gas-hog or motorcyclist. To them, the car sounds like it is running but in a 'Walter Mitty' sort of way . . . pocket-ta pocket-ta pocket-ta . . . and then the light changes. <GRINS> Bob Wilson |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(bwilson4web @ Aug 28 2007, 01:30 PM) [snapback]503356[/snapback]</div> Quote:
I tried the force-charge yesterday and it worked as advertised. Thank you efusco! The thread I had read long ago entailed pushing the gas pedal to the floor twice, and the car would charge by itself without holding anything down. Does that ring a bell? | |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 20 | <div class='quotetop'>QUOTE(Display Name @ Aug 29 2007, 08:50 AM) [snapback]503724[/snapback]</div> Quote:
My Car: 2003 Prius Package: #1 Nominated 2 Times in 2 Posts TOTM Awards: 0 Friends: 5 | <div class='quotetop'>QUOTE(Display Name @ Aug 29 2007, 08:50 AM) [snapback]503724[/snapback]</div> Quote:
Bob Wilson | |
| Senior Member Join Date: Apr 2004 Location: Cambridge, UK
My Car: 2005 Prius Package: T Spirit Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Display Name @ Aug 28 2007, 08:20 PM) [snapback]503348[/snapback]</div> Quote:
I'm far from convinced that attempting to "manually" charge the battery first will work out more efficient overall than just letting it run at high revs up the hill. | |
| charging procedure for 12 volt battery | priusunum | Prius Technical Discussion | 22 | 06-14-2007 02:42 PM |
| Antenna removal procedure | Wendel | Prius Main Forum | 7 | 01-31-2006 01:56 PM |
| Transport Canada's Testing Procedure | Tideland Prius | Fuel Economy | 0 | 01-16-2006 02:22 PM |
| AIC-100i firmware update procedure? | jwdberlin | Audio and Electronics | 6 | 11-11-2005 11:33 AM |
| Two forum procedure questions ... | Ken Cooper | PriusChat Website Questions | 3 | 03-16-2004 10:10 AM |
