Prius Technical Discussion This is a discussion on Bluetooth and Tero within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; <div class='quotetop'>QUOTE(Mel in Mass @ Sep 16 2007, 10:37 PM) [snapback]513486[/snapback]</div> Hello Marvin, Thank you for posting that you also ...
Old 09-17-2007, 10:13 AM   #11
Marvinh
Marvin
Hello Marvin,
Thank you for posting that you also have Treo 650 with bluetooth connected to your 2007 Prius.
I was thinking I was the only one out there.
I do have the handsfree working / connecting (no thanks to Toyota dealer or Toyotta.letstalk.com website).
I did check my Treo 650 - "Firmware: R01.31" (my carrier is AT&T).
That seems higher then 1.05a version, but I don't know.
The harder question, did you get your Treo directory to sync with your car?
Did you just use the "Export to SIM" option, under Treo directory?
All mine does is hang on the Transferring screen.
Melody
Hello Melody,
Sounds like you have the proper firmware version for your Treo 650. However, regarding the 'harder question': I have not tried to export my Treo directory to my car bluetooth. Sorry. My directory in my Treo is very large and I have many different categories. So I'm afraid it would mix things up in the transfer.
So I just add some of my frequently called numbers to the speed dial section of the car bluetooth directory.
Hope this helps. Marvin
Marvinh is offline
Old 09-17-2007, 02:00 PM   #12
bhaynnes
bhaynnes's Avatar
Package: #8
Send a message via AIM to bhaynnes Send a message via Yahoo to bhaynnes
<div class='quotetop'>QUOTE(Mel in Mass @ Sep 13 2007, 09:48 AM) [snapback]511942[/snapback]</div>
Hello Prius fan,
By the number of replies I received, I think there may not be many Tero owners on this list.
I had Treo 600, I upgraded to the Treo 680 in Jan 2007 (just out then).
I looked up Treo 700, I don't see the any changes that would make a difference.
Toyotta.letstalk.com, does NOT list any phones / PDA's by Palm (only the Blackberrys).
Did you get your Treo directory to sync with your car? Did you just use the instruction in the manual?
Melody
I have a treo 680 and the bluetooth works superbly. My battery strength and signal strength show up on the MFD display. It works great.
bhaynnes is offline
Old 09-17-2007, 03:52 PM   #13
O-Mel-Prius
O-Mel-Prius's Avatar
<div class='quotetop'>QUOTE(bhaynnes @ Sep 17 2007, 02:00 PM) [snapback]513802[/snapback]</div>
Hello Bhaynnes,
Wow, now I know there are at least 3 of us that are using Treo in their Prius. That is great news!
It was very discouraging to see NO phones / PDA's by Palm listed as supported on Toyotta.letstalk.com website. Again the harder question, have you tried to export your Treo directory to your Prius telephone directory via bluetooth.
If so, how did you do it?
Melody
O-Mel-Prius is offline
Old 09-18-2007, 08:03 PM   #14
tedmarshall
tedmarshall's Avatar
<div class='quotetop'>QUOTE(Mel in Mass @ Sep 17 2007, 12:52 PM) [snapback]513857[/snapback]</div>
Hello Bhaynnes,
Melody
I too have a Treo 650 (Verizon). When pairing, I also get the situation where the Treo says that pairing is complete but the Prius is still waiting. Making a call from the Treo makes the Prius connect and everything is fine.
Here's how to transfer your entire phone book from the Treo to the Prius:
1) On the Prius, press "Info" (hard button) then "Telephone" then "Phone Book" then "Transfer" then "No Group".
2) On the Treo, go into the contacts list, select category "all" (at the top), then press the options hard key and select "Send Category".
3) For "Send with", select "Bluetooth" and hit "OK".
4) Select the device name of the Prius (probably "HANDS FREE") and hit "OK".
At least on my 650, that does it.
tedmarshall is offline
Old 09-19-2007, 12:04 AM   #15
O-Mel-Prius
<div class='quotetop'>QUOTE(TedM @ Sep 18 2007, 08:03 PM) [snapback]514556[/snapback]</div>
1) On the Prius, press "Info" (hard button) then "Telephone" then "Setting" then "Phone Book" then "Transfer" then "No Group".
TedM - IT WORKED!
I now have my Treo phone directory transferred to my car.
(I have over 1000 entries in Treo 680, have some clean up to do)
Now I don't have to use my Treo to call people in my directory when I'm in my car.)
Thank you, Thank you so much for posting these instructions.
I could not find these instructions any where else. I tried several other ways to transfer but none were successful. You’re my hero - I love this list.
Melody
Bluetooth for non-Bluetooth Prius tomdeimos Prius Modifications 2 07-20-2006 09:19 PM
Bluetooth adapter for non bluetooth phone Renocat Prius Main Forum 3 07-20-2006 03:30 PM
Bluetooth adapter for use with non-Bluetooth phone chris_b_01 Audio and Electronics 11 07-17-2004 11:40 PM
Bluetooth car, phone - now you need a Bluetooth Headset! Danny Audio and Electronics 8 04-01-2004 12:18 PM
Need a Bluetooth adapter for a non Bluetooth phone. Steve Goldenberg Audio and Electronics 7 01-14-2004 11:21 AM
