Prius Technical Discussion This is a discussion on 08 Prius struck by Lightning! within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Well, the day has arrived. I have repaired a number of cars struck by lightning and today I was assigned ...
lightning!, prius, struck
Old 07-14-2008, 08:18 PM   #1
Bear68
Nominated 3 Times in 1 Post
Friends: 5
Default 08 Prius struck by Lightning!
Well, the day has arrived. I have repaired a number of cars struck by lightning and today I was assigned an 08 Prius that got the Big Spark. This should be a rather interesting case since it is the first Hybrid I have ever heard of being hit by lightning.
For peace of mind, the driver and his child are completely safe and uninjured. The bolt seems to have hit the radio antenna, leaving only a somewhat charred circuit board. The scantool could not communicate with the following computers: Engine ECU, Hybrid ECU, HV Battery ECU, and Cruise Control ECU. The radio is understandably dead. The CAN communication is also inoperative. At this point, my diagnosis is on hold awaiting authorization to order a new Gateway ECU.
I will be give more information as I continue, (providing the insurance company decides not to total the car) and I will photograph any interesting sights, including the antenna remains. This should get Very Interesting!
Toyota Ceritified Master Diagnostic Tech, Prius Certified
"The only foolish question is the one left unasked."
Bear68 is offline
Old 07-14-2008, 08:40 PM   #2
TonyPSchaefer
Ruler of Omicron Persei 8
TonyPSchaefer's Avatar
Nominated 4 Times in 2 Posts
Send a message via AIM to TonyPSchaefer Send a message via MSN to TonyPSchaefer Send a message via Yahoo to TonyPSchaefer
Friends: 14
Default Re: 08 Prius struck by Lightning!
There was a concern in '04 and '05 that hybrid would be more prone to lightning strikes. If word of this single incident gets out, the anti-hybrid media could have a field day.
Than again, perhaps the wait-time would drop. Hmmmm
TonyPSchaefer is offline
Old 07-14-2008, 08:44 PM   #3
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 5
Wow. Was the damage to the other lightning-struck cars limited to electronic circuitry?
Was the Prius occupied at the time it was 'Chosen'?
tochatihu is offline
Old 07-14-2008, 08:48 PM   #4
Bear68
Friends: 5
#1: Surprisingly , no. I had a Highlander that had an ABS wheel speed gear cage get damaged. (slight melt spot, enough to not read properly)
and a Corolla that had the antenna cut cleanly in two.
#2: Yes, I believe it may even have been in motion at the time of the strike.
Bear68 is offline
Old 07-14-2008, 08:51 PM   #5
Bear68
Friends: 5
Personally, IMO, the HV battery and invertor assmebly and motors are so well insulated already and isolated from the car body (unlike the 12V system) that the HV system is actually LESS likely to be damaged by lightning. Unfortunately, the ECUs are not so well protected....
Bear68 is offline
Old 07-14-2008, 08:58 PM   #6
Ichabod
Artist In Residence
Ichabod's Avatar
Send a message via AIM to Ichabod
Friends: 6
That does sound interesting. I wouldn't expect the electronics to fare well, but I would expect people to be OK, due to the skin effect (commonly mistaken for the Farraday cage effect).
I don't suspect that even blown fuses would stop lightning from jumping through various sensitive bits... I think most interesting in your report might be the difference between the repairs on a Prius vs a "standard" car. Maybe you can share a synopsis of some other car's lightning repair for the sake of contrast?
Ichabod is offline
Old 07-14-2008, 09:30 PM   #7
JamesWyatt
Seņior Member
JamesWyatt's Avatar
Same car?
Thunderstorms+prius...help me
JamesWyatt is offline
Old 07-14-2008, 10:15 PM   #8
Bear68
Friends: 5
Originally Posted by JamesWyatt View Post
Sounds like the same car! I will keep things anonymous for obvious reasons, but I see no harm is sharing diagnosis and repair details.
For Ichabod: Most cases wind up with ECUs being shorted and burned since the voltage is usually travelling into the skin and body of the car and therefore actually finds ways to bypass the fuses. Strangely, there were NO blown fuses on this Prius. Radios are susceptable if the strike is on the antenna, otherwise, the engine ECU, sometimes the ABS ECU, and rarely the SRS ECU can be affected. No two have been identical so far. Diagnosis begins with checking fuses and power and ground to whichever ECUs are having issues with communication.
One step at a time is generally the best way to proceed. I would rather avoid replacing computers that are good but recieving bad input from other computers or sensors. I generally also try to look for the entrance and exit "wounds". In this case, the entrance is obviously the antenna. I have not yet identified the exit. The waiting game has begun, waiting for the insurance adjuster, then waiting for the insurance company to determine if they will pursue repairs or total the vehicle.
Whoops! My mistake!! I didn't read the other thread all the way through. Not the same car! This one is a black 08, but the codes cannot be retrieved from the various ECUs until the gateway ECU can communicate properly.
Last edited by Bear68; 07-14-2008 at 10:22 PM. Reason: more info from another thread
Bear68 is offline
Old 07-14-2008, 10:20 PM   #9
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 20
whew, well that's a new one to DH. let us know how the gateway ecu works out if they approve it.
galaxee is offline
Old 07-14-2008, 10:23 PM   #10
galaxee
galaxee's Avatar
Friends: 20
what were the can signal line voltages on the high and low side?
galaxee is offline
Silly Question: Lightning Strikes legendx Prius Main Forum 9 03-31-2008 05:07 PM
'Deal struck' at UN climate talks TimBikes Environmental Discussion 5 05-04-2007 04:02 PM
Pedestrian struck, killed in Anaheim; driver flees IsrAmeriPrius Prius and Hybrid News 23 01-28-2007 01:38 AM
Lightning and Prius and looking for journal scruopec Prius Main Forum 20 07-24-2006 09:10 AM
Lightning Bluebell Prius Main Forum 3 06-10-2005 10:53 AM
