| Prius Technical Discussion This is a discussion on 2001 Prius - Stealth Mode within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi, I am new owner of a 2001 Prius. I was hoping you all could give me a hand trying ... |
| 2001, mode, prius, stealth |
| Junior Member Join Date: Jul 2008
My Car: 2001 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi, I am new owner of a 2001 Prius. I was hoping you all could give me a hand trying to understand something here. Through some research online and through this board, I tried to educated myself on the functioning of the Prius. It is my understanding that the Prius is capable of driving in battery only (stealth mode) under certain circumstances Those being: 1. The engine is sufficiently warmed up 2. The batteries have sufficient power 3. You are traveling at 42mph or below 4. You are not attempting to accelerate quickly. I am certain over the weekend that I met that criteria several times, one specifically being when I was stop and go in Chicago traffic for an hour. Throughout that entire time, the lcd display always showed there was engine assistance. The only time the engine shuts off is when I come to a complete stop, but promptly turns back on when I start moving. Am I understanding the technology incorrectly? Does this not happen in a 2001 prius (U.S.A. model)? Thanks for the help! |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | One of the improvements that came with the newer HSD version was the upgrade to electric A/C. Before that, the engine would have to run to keep you cool. Another was the tolerances for when the engine shut off and came back on. This was quite obvious with temperatures below 20F. It happens at the other extreme some too, as you likely just saw in the summer crawl through heavy traffic... even without the A/C running. Figure if the wait will be longer than 15 minutes, the engine will eventually run briefly for some reason or other. . |
My Car: 2001 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
| Stealthing the Stealth Mode. | whitespider | Prius Main Forum | 11 | 07-24-2007 05:21 PM |
| Glide vs. Stealth Mode | dachshund | Prius Main Forum | 3 | 09-14-2006 07:35 PM |
| 2001 prius service mode affects mpg | statultra | Prius Technical Discussion | 4 | 06-17-2006 11:35 PM |
| Noisy Stealth mode | sdsteve | Prius Modifications | 27 | 05-31-2006 02:25 AM |
| Stealth Mode | Champaign Jim | Prius Main Forum | 13 | 02-10-2006 04:42 PM |
