| Prius Technical Discussion This is a discussion on shift to neutral takes a second - why? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; If there is no disengage, then it isn't a true neutral. One of the complaints with my eCVT maxi scooter ... |
| neutral, shift, takes, why? |
| | #11 |
| Senior Member Join Date: Sep 2007 Location: Davis, CA
My Car: 2007 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | If there is no disengage, then it isn't a true neutral. One of the complaints with my eCVT maxi scooter (Burgman) is that there is no neutral. Sure, I can push it around the garage but I have to overcome the friction of the drivetrain. But once in motion and with the scooter on, I can not reach 'neutral' because the drivetrain is always engaged. How is this 'neutral' in motion accomplished in the Prius if there is no disengage? |
| | #12 |
| Senior Member Join Date: Mar 2005 Location: bay city, ca
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Neutral is accomplished by opening the field winding circuit on both motor generaters. This allows the wheels or the engine to turn independently of the other. |
| What does the B shift do? | captainjimbo | Newbie Forum | 5 | 07-18-2008 12:48 PM |
| Shift happens... | burritos | Fred's House of Pancakes | 3 | 02-16-2007 10:47 PM |
| It Takes a Slam | mouztrpd | Prius Main Forum | 2 | 12-29-2005 09:02 AM |
| How do you Shift to Neutral Without Starting Engine | trmaddux | Care, Maintenance and Troubleshooting | 1 | 09-28-2004 09:03 AM |
| Can you shift too much? | HarleyMYK | Prius Main Forum | 29 | 07-22-2004 04:54 PM |
