| Prius Technical Discussion This is a discussion on Auto-AC Button on Steering Wheel within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Originally Posted by Sheepdog 80* is surprisingly cool when it's triple digits outside! +1 yesterday after my teacher inservice i ... |
| auto-ac, button, steering, wheel |
| | #21 |
| Senior Member Join Date: Jun 2007 Location: Kilgore, TX
My Car: 2007 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | +1 yesterday after my teacher inservice i got back into my car (3pm-ish) and the MFD thermometer read 133* took 45 minutes for the A/C to get the temperature down to 80... ![]() but it DID slow down as it approached 80 inside, just as it's supposed to. then there's the fact that the outside temp finally "cooled down" and settled in at 104. a 24* differential from inside to outside is pretty significant if you ask me. good thing Pablo's AC is so effecient! |
| | #22 | |
My Car: 2007 Prius Package: #5 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
try it sometime. it has been my observation that at times the internal combustian engine will fire up for no other logical reason other then to keep the cabin warm. now if the internal combustion engine fires up at longer intervals like at least 5-10 minutes, its pretty obvious that its charging the battery up but if you keep the cabin air temperature down, the engine will only stay on for a couple minutes, here and there, and then shut down for the 30 minute period the prius's traction battery fully charged (as defined as 70 %, heh) has enough energy stored in it to keep the car in full ready mode, in park, for at least 30 minutes without needing the internal combustion engine to charge it. find a couple stop watches and you will notice that the gasoline engine will fire up more often in a prius car with its cabin temp set higher then the other prius car with its cabin temp set lower can you hear the battery cooling fan? i have never heard it comming on most of the time on my 30 minute lunch breaks at 2:35 am in the morning i sit in my car in full ready mode (because at 30-45 minutes in accessory mode is kind of pushing it), 5 days a week, and theres a direct link from what i have seen so far after you have tried this and it seems to be the case please report back on the following section totally unproven theory section ======================= the prius fuel tank has a sensor in it to correct the fuel level when you go up and down hills, the headlight sensor will adjust the HID lights as you go up and down hills, these sensors report back to the prius and the prius takes this information and forces your car to burn gasoline @ 25 mpg uphill to keep the battery safe so it lasts a long time | |
| | #23 | |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Quote:
__________________ Black 2006 package #7 Northern Michigan | |
| | #24 |
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | just returned from a 900 mile trip over 5 days and we also started AC at 70... but as the drive goes on and the humidity of the air goes down and cabin temp equalizes, (not easy because of the radiant energy of full sun) our comfort needs eventually had us at 75º... now that might not seem good to most, but keep in mind, temperatures are all relative and based on what you are acclimated to. daily average high temps in summer around here is 77º in the south where temps are much higher, one could probably set temps to 80 and be ok.
__________________ My 2006: Last tank 463.1 miles @49.2 pump (49.4 computer) 4.22 cpm winter mpg 50.70 summer mpg 54.59 lifetime: 33,038.3 miles 52.79 mpg pump (54.04 mpg computer) 5.74 cpm My 2007 Zenn Driven 5945 miles, 2.01 cpm/ 105 mpg (at $2.05/gal), 4.04 miles/ Kwh Savings over my Prius $302.66 The Corolla...573.26 The REAL SAVINGS from not driving Corolla 657.39 +Prius= 958.18 (excludes maintenance costs...would be unfair to ICE vehicles) My Plate: DUALPWR (Dual Power) |
| 2006 EV button effecting steering wheel controls? | sack | Prius Modifications | 7 | 09-26-2007 05:24 PM |
| Question on modifying steering wheel button for backup camera activation | crypter | Prius Modifications | 0 | 03-04-2007 02:31 PM |
| Steering wheel button illumination/brightness question | Gaelyn37 | Audio and Electronics | 3 | 02-26-2007 01:45 PM |
| Steering Wheel Button Lights | Warwind | Prius Main Forum | 2 | 11-06-2006 04:34 PM |
| Can I adjust the Steering Wheel button Brightness? | macreative | Prius Main Forum | 1 | 09-24-2004 01:22 AM |
