Prius Technical Discussion This is a discussion on Battery Charging Problem within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; My 2004 Prius is not charging the HV battery, only three to two bars and quickly drop to one bar. ...
battery, charging, problem
Old 08-07-2008, 08:30 PM   #1
mcorsino
Unhappy Battery Charging Problem
My 2004 Prius is not charging the HV battery, only three to two bars and quickly drop to one bar. The engine continuisly is charging the battery but it wont last to long, most of the time is running with the gas engine.
I just bring the car to my local dealer, they check the car with a scanner and they didnt find any trouble code. They program the HV ECU because it is a Toyota campaign, they charge me with $72 for the diagnostic.
Guess what? the car continues with the same problem, last night driving to our church we heard a loud noise coming from the back of the car, when we check it we found that is a fan close to the battery.
Did anyone have this problem before?
mcorsino is offline
Old 08-07-2008, 08:58 PM   #2
Nominated 1 Time in 1 Post
Friends: 24
Default Re: Battery Charging Problem
Where are you located? How many miles on the car? Are you the original owner? Any prior problems with the car?
It sounds, to me, like your battery might be bad, but it's hard to tell for sure.
efusco is offline
Old 08-07-2008, 09:58 PM   #3
mcorsino
We are from Puerto Rico, the mileage is 56.065, i am the original owner and this is the first time that we have a problem with the car. I just bought the car for my wife she only used it for her job and the church, normally driving it no more than 35 miles daily
mcorsino is offline
Old 08-07-2008, 10:31 PM   #4
morpheusx
Professor Chaos
morpheusx's Avatar
just curious if you are trying to drive with just yellow arrows.
morpheusx is offline
Old 08-08-2008, 11:06 AM   #5
richard schumacher
nacreous lacquer
What MPGs are you getting?
There is a vent opening on the right side of the rear seat. This vent must always be kept open and not blocked.
If you do not have them, buy copies of both the Prius Owner's manual and the Prius Scheduled Maintenance Guide. They will save you trouble and money. Any dealer should be able to order them.
richard schumacher is offline
Old 08-08-2008, 07:55 PM   #6
mcorsino
I am getting 45MPG, about the battery vent i will check it, Thanks for the info.
mcorsino is offline
Old 08-09-2008, 09:37 AM   #7
David Beale
David Beale's Avatar
If the battery actually has a problem it will eventually set a code that the dealer will see. It may just be the heat is affecting battery operation. 45 MPG is fine with short trips.
When the battery is hot you WILL hear the battery fan. You can identify the noise is the fan as the sound will appear to be coming from the vent on the top left side of the rear seat.
David Beale is offline
Old 08-09-2008, 10:33 AM   #8
archae86
right side if you are taking the reference while looking toward the front of the car.
archae86 is offline
Old 08-09-2008, 11:41 AM   #9
rigormortis
Package: #5 Touring
thinking about this, i bet the easiest way to test the HV battery at home would be to start the car, put it in drive, keep your foot on the brake and accelerate and sit there and force the prius to charge, after a few minutes or maybe 30 minutes or longer if it does not go all the way up then theres probably something wrong.
another way to test it the battery i guess would be after u get 6 bars, maybe turn the car off for a day or more and see if you get the 6 bars? hmm.. not sure about that one, but i guess it could indicate if the battery would hold a charge or not???
don't let off the brake pedal or it will leap forward and hit something, and that is not a warranty claim, heh
with no codes to read, the only thing the dealership can probably do, i bet, is to fly the guy over with the prius battery charger....
i dont know if toyota has a way of checking the individual modules, this should all be covered with the built in HV battery ECU diagnosis, and i agree with others, until your car actually throws a code, toyota can't help you
rigormortis is offline
Old 08-10-2008, 01:11 AM   #10
Friends: 24
Force charging should chart it up in 5 minutes or less...at least to the first green bar.
efusco is offline
Charging battery westex39 Prius Main Forum 1 02-06-2008 10:58 AM
Wall charging HV battery shortbus Prius Modifications 16 01-05-2008 10:55 AM
Charging HV battery whodat Prius Modifications 4 07-22-2006 04:49 PM
Battery not charging on decent priusjunky Care, Maintenance and Troubleshooting 4 07-22-2005 01:56 AM
Charging problem? mongo Care, Maintenance and Troubleshooting 5 08-27-2004 05:37 PM
