| Prius Technical Discussion This is a discussion on Traction Control within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I Just Got A 2007 Prius Every Once In A While My Car Will Slip/jerk Forward And The Traction Control ... |
| control, traction |
| Junior Member Join Date: Aug 2008 Location: DIRTY JERSEY
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I Just Got A 2007 Prius Every Once In A While My Car Will Slip/jerk Forward And The Traction Control Light Will Come On I Was Driving On Smooth Roads This Has Happened Several Times And I Took It To Dealer Which Found The Traction Control In Normal Working Order Anyone Experience This? |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | Do you have any punctuation on your keyboard? It would help a lot with the readability of your post. Removing the ironic capitalization would help too. Are you saying that traction control activates from time to time on a smooth dry road surface, or that traction control gets set off from a slippery section? Tom |
My Car: 2007 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 7 | Quote:
| Prius named PHriuS Join Date: Feb 2008 Location: SE PA
Occasionally, I'll feel a small surge or slip when running over expansion joints on a concrete highway, especially when accelerating uphill. Have never seen a Traction Control Light however. | |
| Senior Member Join Date: Apr 2008 Location: Canada
My Car: 2008 Prius Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Sorry for the punction errors I type to fast and don't pay attention. The traction control light comes on smooth surfaces sometimes as I apply the brake the car will jerk forward and the traction control light will come on and the car will fishtale like its trying to obtain traction. This only happened twice. The dealer said it was operating normally |
| Senior Member Join Date: Jun 2007 Location: Kilgore, TX
My Car: 2007 Prius Package: #3 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | This has happened to me twice, both times while accelerating from a dead stop. The first time was in the rain, so obviously I didn't think anything of it, but the second time was last week at a red light on a smooth, dry, surface and it took me a full minute to get Pablo to calm down and proceed normally... Not sure what happened... |
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | 2 main reasons cause this. #1 the Goodyear Integrities, I bet your Integrities have at least 20,000 miles on them, they turn into slick tires at about 15 - 20,000 and into ice skates at about 25 - 30,000 #2 overinflation (above 44 PSI) |
| Junior Member Join Date: Feb 2008 Location: Pennsylvania
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Need to be able to disable traction control manually in an emergency. Last winter I was stopped on a slight upgrade. Road was slushy but not bad. When I started out the wheels started to slip. The traction control took over and all the car would do was make short lurches. Took forever to get through the intersection. If I could have disabled the traction control the wheels would have spun for just a second or two and then would have gripped and I would have been OK. Truck coming the other way stopped and laughed at me as I couldn't get going. First car with traction control and will be my last unless they put some kind of manual override on it. |
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | d.j.turner@hotmail.com, Welcome to PriusChat. You've come to the right place to get info on your Prius. FWIW, for a good discussion of how the traction control works -- and doesn't -- see Post #4 in this thread: Traction Control --- It worked... I Think. You might also use the search function -- in the blue bar at the top of the page -- using "traction control" to turn up other threads of interest. Last edited by Rokeby; 10-18-2008 at 08:37 AM. |
| Traction Control | rlaurent | Prius Technical Discussion | 130 | 06-13-2008 03:28 PM |
| Traction Control | adamwmcanally | Care, Maintenance and Troubleshooting | 8 | 05-14-2007 10:36 AM |
| Traction Control | dhoward | Prius Main Forum | 22 | 04-27-2007 09:22 AM |
| Traction Control | sparkymarvin | Prius Modifications | 42 | 06-07-2005 02:38 PM |
| Traction Control | kevin54 | Prius Main Forum | 9 | 04-08-2005 11:12 AM |
