Ottonavi HU: How to customize (a bit) the UI
Discussion in 'Gen 3 Prius Audio and Electronics' started by Bulle, Feb 12, 2012.
  1. Bulle
    Bulle Member
    378
    Hello Theblen,
    welcome on this forum.
    For the DVD menu; you will have to post a picture to show how it looks like.
    About the front page; yes should be possible; you can use either the RRUIEditor or the RRUITool. (look at post #1)
    It may be that your shell (2.87.3) is special; I don't have that particular one so I can not test it.
    But if you want, you can zip it and post it here or sent it to me privately and I'll take a look.
  2. theblen
    theblen Junior Member
    Sabah, Malaysia
    i will.
    wait a bit cause it is holiday here. will post the picture
    and try to zip the files. just tell me which files you want
    and also the "Apps' menu is missing 1 icon. i guess it is the iPod icon. maybe because my unit doesnt support it?
  3. Bulle
    Bulle Member
    378
    Well that would be sad; but I'm quite sure your iPod is supported; it probably just needs to be enabled in the menus.
    Please zip the I9 folder and send it to me; I'll take a look.
  4. theblen
    Sabah, Malaysia
    okay i will run the explorer and copy the i9 folder for you to see
    this is the picture: 20140728_133811.jpg
  5. theblen
    Sabah, Malaysia
    there is DVD button on the right side of the screen so i want to change that to Movie from the Apps folder.
    i will show you the Apps menu later. right now i am driving. kinda hazard to drive n shoot LOL
  6. Bulle
    Bulle Member
    378
    OK perfect; should work; it's the standard BlackOrange skin. Should be easy to change.
  7. theblen
    Sabah, Malaysia
    This is how my Apps menu looks like at first:
    And after i apply the skin, i miss a few icons:
    i dont know maybe the firmware is different
    but if u can help me cause i really like the Metal design, but lacks of icons confuses me. lol
    i wish i can edit on my own. haha im a slow learner
  8. theblen
    Sabah, Malaysia
  9. Bulle
    Bulle Member
    378
  10. theblen
    Sabah, Malaysia
    Oh i take them out to save some space for the big zip files ha3.
    Well. I will resend you later.
    I really love you "Turn Off LCD" button on the front. Kudos!
  11. frog2050
    frog2050 Junior Member
    RUS
    Доброго времени суток.
    Есть проблема с редактированием скина "F150 magnum DAB v1.rrui" F150 magnum DAB v1.zip — Yandex.Disk
    Пропадает компас и индикатор заряда акб телефона подключенного через Bluetooth
    Как бы это можно было исправить или помочь
    Eng.
    Good day.
    There is a problem with editing skin "F150 magnum DAB v1.rrui" F150 magnum DAB v1.zip — Yandex.Disk
    Lost compass and LED battery charge phone connected via Bluetooth
    How this could be correct or help
  12. Bulle
    Bulle Member
    378
    Hello frog,
    welcome to this forum.
    the RRUIEditor supports only the skins with old widgets; new widgets like compass are not supported.
    To get around this, you need to finish the editing by using the RRUITool which will let you edit each widget in a text file which you can rebuild later in a skin file.
    It's a bit tricky but feasible.
    Look at post #1 for more info; also you can download the latest version here:
    https://dl.dropboxusercontent.com/u/63503986/RRUIToolv12M.zip
    Good luck,
    Bulle
  13. alex.grivnik
    alex.grivnik New Member
    Ukraine
    2003 Prius
    Good day
    I encountered some problems, maybe someone can help me.
    1) I used RRStringsTool to correct errors in Ukrainian localization and ran into a problem that the choice of the Ukrainian language in the settings, the system displays the English strings.
    2) Program in the field RRUIEditor VIEW AS LANGUAGE reflects only the languages from English to Dutch. It makes not possible to verify the Ukrainian localization on the PC.
    I would be grateful for your help, Alex
  14. Bulle
    Bulle Member
    378
    Hello Alex,
    1) Very strange problem. First, what is the value of the line "language=" in the config.ini file in the I9 folder?
    2) Unfortunately the RRUIEditor (done by RoadRover) cannot be changed easily as we don't have the source code.
    So there are 2 things you can try:
    a)-Copy all your Ukrainian strings and replace all the Chinese strings. Build a new lang.dat with that and select Chinese in the RRUIEditor.
    b)-You can also copy all your I9 folder on a PC and run the RoadroverEmulator; that will let you test almost every screen.
  15. alex.grivnik
    Ukraine
    2003 Prius
    I tried to replace the Russian strings and it were English.
    When compared using Hex editor I concluded that the problem in compiling lang.dat. As you can see on image.
    Have to edit in Hex.
    #555 alex.grivnik, Sep 13, 2014
  16. Bulle
    Bulle Member
    378
    Send me the lang.txt file with the corrections and I will take a look.
  17. alex.grivnik
    Ukraine
    2003 Prius
    I would appreciate
    • lang.txt
      File size:
      891.3 KB
      1,825
  18. Bulle
    Bulle Member
    378
    It looks like you put an extra TAB control character on every Ukrainian line.
    There should not be any special character on a line as this would be interpreted as a new line.
    So in effect you only created half of the strings.
    Please read the instructions carefully and it should work!
  19. alex.grivnik
    Ukraine
    2003 Prius
    Thank you,Bulle.
    Sorry that disturbed.
  20. alex.grivnik
    Ukraine
    2003 Prius
    Hello
    I noticed small flaws while using the Ukrainian language, such as the use of on-screen keyboard and date format.
    That is:
    1) The date format in the desktop device has an English version. And should be dd mm yyyy (both in Russian)
    2) Screen Keyboard offers a Latin keyboard. I would like to have and Cyrillic (Screen Keyboard offers a Latin keyboard. I would like to have and Cyrillic (again, as in the use of the Russian language).
    So the question where these parameters are defined in the i9. That is, to edit or Black orange.rrui registers Windows.
