2015 Prius Auto A/C Takes a while to turn on, normal?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nanoxnano, Aug 5, 2015.
  1. nanoxnano
    nanoxnano Junior Member
    26
    Hello everyone. I just bought my Prius (Model 2) about 3 months ago and I starting to notice, when I hit the AUTO A/C button, the A/C lags and takes a good 5 seconds or so to turn on. My previous car, a Toyota Corolla, would turn on the A/C right away. Is this normal?
  2. working1
    working1 Active Member
    121
    111
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    This a new behavior on newer cars even in non-hybrids as I recently noticed the same behavior in a 2014 corolla rental. It allows the a/c to get to chilling before blasting the hot air built up in the dash on you minimizing the "hair dryer effect".
    nanoxnano and ftl like this.
  4. carolD
    carolD Junior Member
    82
    florida
    2015 Prius c
    I live in Florids. My salesman stressed that I do not have to turn the AC off before shutting car off. When I start car up it takes less than 10 seconds for cold sit to come out. I had always in other cars I have owned shut the air off before shutting the car off but the dealer told me that is not necessary in this car.
  5. Den49
    Den49 Member
    498
    268
    Maryland
  6. bisco
    49,816
    mine also lags, always figured it was normal.
    the salesman is misinformed. if you leave it on, your going to have mold growing in the system.
    perhaps this is a new dealer scheme to sell more a/c refresh services.
    the best practice is to turn the fan up and shut the a/c off a few minutes before parking. this helps to dry everything out.
  7. dawesy
    dawesy Junior Member
    Mines never off. Had the car 5 years now and no funky smells to date.
    iPhone ?
  8. qdllc
    qdllc Senior Member
    1,370
    399
    Mine lags. I presume on AUTO it's taking a variety of readings and getting the system pressurized before it knows how hard to run the system to try an reach the set temperature.
  9. Mendel Leisk
    38,985
    From the Owners Manual:
  10. carolD
    82
    florida
    2015 Prius c
    Hi. I too just got a C2, three weeks ago. The same exact thing happened to me. I was concerned because it was the first time in 3 weeks that it happened. It used to come right out cold. Now it is taking 5 to 10 seconds to get cold. I live in Florida and use the air all the time. But that wS the first time it happened to me.
    Yes I was told the same thing by my salesman. He told me to just shut the car off and that the ac could be left on. That is new to me for I always used to shut the air or heat off before shutting the car down.
  11. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Completely NORMAL.
  12. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    AFAIK, turning the A/C off on other cars simply reduces the engine strain on startup. On the Prius, the A/C is electronic and not driven by engine belts, so on/off doesn't have the same effect on startup. I used to turn it off on our van and still do on my truck, but the Prius simply stays on Auto. In some climates, odor can be a problem with any A/C and turning the A/C off and the fan on high a few minutes before getting home might help dry things out to minimize such odors. I've lived in climates from WI to IL, CA, CO, AL, HI and AZ and never had the problem severe enough to worry about, so I don't know how true this is.
  13. qdllc
    qdllc Senior Member
    1,370
    399
    My dad always shuts off AC before turning the car off.
    Back in the day, AC was an ADDITION to a car and put a significant drain on the power system. Now that its standard, the electrical system is designed with the AC system in mind. So, it's not really necessary to do that.
    My pickup truck had the AC compressor always on. In other words, it would cycle in order to ensure the system was pressurized. If you had the AC turned off, it just cycled on an infrequent basis. I'm not sure how or if that was "better" over it only being on when the AC was turned on, but IIRC, if you NEVER run the AC, it harms the components (they last longer when used regularly versus no use).
  14. Mendel Leisk
    38,985
    Multiple responders saying it's normal, noted in the Owner's Manual, and still people chime in with "yeah but what's wrong?" lol.
    It's like watching one of those freeway pile ups: ever gaining new contributors.
  15. el Crucero
    1,628
    699
    Inland Empire
    You can lead a horse to water, but you can't make him drink! :rolleyes: (now I am really showing my age!)
  16. CR94
    CR94 Senior Member
    2,642
    1,140
    Northwestern S.C.
    Even if he does drink, naive new colts are born every day.
  17. Virg
    Virg Junior Member
    28
    Austin Texas
    This is normal for the automatic air con system in the Prius. The system in my Mercury did the same. I'm not a fan of the automatic systems...but no choice in my Prius. Can't really see the bother in just turning on the air and choosing the blower speed. But....
  18. qdllc
    qdllc Senior Member
    1,370
    399
    Other than "convenience," it helps the Prius save energy by adjusting the AC for optimal performance vs. energy conservation. Personally, I like it as compared to always looking for that "sweet spot" on the controls of my other vehicle.
    I have a similar issue with space heaters at home. Give me one with a digital thermostat. Dials force me to calibrate and mark the unit so I know what setting is "comfortable" compared to just picking a temperature and letting it run.
