03' Classic Prius and scanguageII
Discussion in 'Generation 1 Prius Discussion' started by w2co, Jan 30, 2010.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,210
    Madison, Wisconsin
    Thanks for the update Chap.
    Sometimes the scangauge is so much better than hooking up through Techstream.
    Delta SOC is a reading that would be interesting to find for programming into Scangauge.
    Is it in the list and I just missed it?
  2. ChapmanF
    15,169
    I see it in the XML file at sourceforge - apparently parameter #bc in the battery ECU. The short label suggested for ScanGauge is dSC.
    -Chap
  3. ChapmanF
    15,169
    Speaking of Delta SOC, anybody want to take a stab at what it actually means?
    It's mentioned twice in the old hybrid course sections from autoshop101.
    Section 3 (High-Voltage Battery) mentions it on page 5, with a graph showing SoC being controlled in a range covering 20% around the target 60%, and seems to imply that this variation is what Delta SOC measures.
    Section 5 (HV Battery Control Systems, Hybrid15.pdf) on page 3 has a similar definition, but adds the words "from one module to the next across the battery group."
    Which invites the guessing game ... between the people who wrote section 3 and the people who wrote section 5, who was closer to right about what the ECU's "Delta SOC" parameter means?
    -Chap
  4. bwilson4web
    15,440
    I remember it as a fixed value returned from the controller. I never found a way to change it but remember it as the +/- value around 60%. But without a way to change it, this remains speculation.
