04 won't start - red car on MFD
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Daox, Apr 28, 2010.
  1. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    Just have someone see if the brake lights come on when you press with normal pressure. The switch might just need some adjustment.
  2. Patrick Wong
    18,199
    6,464
    Yes, any DTC logged by the engine and hybrid vehicle ECUs would be lost.
    In the meantime, I second the advice that you check when the brake lights come on. Position the car so that you can see the brake lights in your rear view mirror, then see how hard you have to depress the brake pedal to get the lights to come on.
  3. Daox
    Daox Member
    196
    58
    US, Wisconsin
    I took the car for a couple drives this weekend, some short some long, no problems at all.
    I will check the brake lights. Is the switch adjustable or is this a replacement deal?
  4. Patrick Wong
    18,199
    6,464
    The switch position is adjustable. However if you find that the switch operates intermittently, then it should be replaced.
  5. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Well, the same thing happened again to my wife yesterday. She drove the car home this time and its sitting in the driveway doing the same thing as before. The reset lasted ~10 days. It is definitely not a brake switch. I pushed very hard on it last night and I got nothing but the dash lit up and red car on the MFD.
    Anyone think this could be 12v related? I didn't think it was before but now I'm wondering...
  6. bwilson4web
    15,407
    There is a little discussed, Toyota diagnostic that consists of an OBD connector and two switched:
    http://priuschat.com/forums/generation-1-prius-discussion/79877-intro-dtc.html#post1116332
    It can flash the last two digits of the error codes on the instrument warning lights. Using these two-digit codes, you can look up in the maintenance manual and/or ask online to see if they match known error codes.
  7. ejlazarus
    ejlazarus Junior Member
    Germantown, TN
    I had a similar proble,m the dealer told mw it as a defective inverter pump. That was replaced todday and all is well. So far so good 61+K miles, 04 silver.
