100,100 miles and looks like Hybrid battery is failing
Discussion in 'Gen 2 Prius Main Forum' started by Docbarb3, May 5, 2015.
  1. Docbarb3
    Docbarb3 New Member
    Mentor, OH
    Starting at about 96,000 miles I noticed that the battery charge data was always in green...prior to that it had been in the blue area. I asked the Toyota technicians about that and they had no answer. Shortly after that the 12 Volt battery failed in very cold weather. I replaced that. I took the car in for 100,000 mile service at 100,100 miles. They changed the inverter fluid and the coolant fluid. Driving away from the Toyota repair shop I noticed the Hybrid battery light was on purple(the very bottom of the charge) for the first time ever. I took it back and they said maybe the accessories had been on the whole repair. Next time driving car, the battery dropped to purple whenever I stopped for a few minutes. It very quickly went back to green as soon as I started driving (within 3 minutes). I am so confused and not completely trusting the toyota repair dept. Was the light staying green a sign of an impending problem? Could the fluid change have caused a problem? Could it have anything to do with the 12 volt battery failure? Assuming the hybrid battery is failing is there any chance Toyota will replace it for free since I am so close to the 100,000 miles and problems may have started before 100,000 miles?
  2. JC91006
    16,498
    8,408
    If the car hasn't thrown a failure code, there's no reason for Toyota to think the battery has failed. It may be weak but hasn't failed
  3. Docbarb3
    Docbarb3 New Member
    Mentor, OH
    Thanks for responding. The car threw the failure code C2318 two months ago which is when they replaced the 12 volt battery. It is definitely rapidly losing its charge now. Why else would it go into the purple all the time?
  4. JC91006
    16,498
    8,408
    Your symptoms sound like a hybrid battery issue but until the car throws a code, Toyota won't do anything for you. Your chances of getting it covered are pretty good if it failed today.
    Changing the fluids would not do this to your car's hv battery.
  5. claypot2
    claypot2 Junior Member
    34
    Miami
    Have you noticed your car doing some mild revving sounds at stop lights? When my battery was going (at about 110,000 miles for me) my only symptom was the engine revving at stop lights on occasion. Then all of a sudden one day every warning light that exists on the console lit up. The car looked like a Christmas tree. Took it to the dealer immediately because I was afraid to drive it and they said it was the hybrid battery. I did not believe them at first - at all. Then did a little research on prius chat and found that was indeed a sign of the hybrid battery dying. Toyota Paid for the battery but I had to pay the labor.
  6. miso03
    miso03 Junior Member
    44
    Bratislava, Slovakia
    Expect your battery to fail soon (maybe in one month approx), because these are the symptoms of failing HV battery. By symptoms I mean discharging and charging rapidly (at least on MFD SOC) in very short time. Normally totally drained battery would charge to top blue bars not earlier than at least 5 minutes of driving. Mine is taking 10 minutes from this SOC but I get one purple bar very rarely, like 5 times a year. 110 000 miles on her and still going.
  7. bisco
    49,798
    anyone else notice a lot of these lately?
  8. Sarge
    Sarge Senior Member
    1,311
    767
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I concur with Miso03.
    My HV battery in my 2006 failed about 2 years ago, at 170K miles - unfortunately well out of warranty.... - and exhibited the same symptoms you described (rapid extreme charge & discharge in uncharacteristic ways, like driving at steady speed on flat ground), about 2 weeks before failing.
    The car makes it VERY apparent when it fails, the MFD will say "Problem!" (IIRC) across the top of the screen, and all your dash lights will come on like a Christmas tree.
    The GREAT news is that the car will not strand you - you can still drive it, but it may go into turtle (self-preservation) mode if the battery is real bad. In my case, the first 2 days or so the car drove 'normal' despite the lights being on, but by day 3 it would only last a couple minutes before it would go into safety mode, until I pulled over and rebooted. ;-) That would buy me another 5 minutes.
    Anyway, day 4 I parked the car until I decided what to do. Note that it is NOT recommended to continue driving like this, as there is risk of causing further damage, but it clearly designed to at least not strand you.
    Finally, Toyota only wanted to sell me a brand new pack for $3K, so I seeked out a private rebuilder who did it for $1200 instead, and also backed his work for a year / unlimited mileage.
    2 years and 48,000 miles later, still running like a charm!
    Great car. :)
    Cheers!
  9. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    ...meaning, lots of folks worried about possible batt failure at 100,000 miles? or 8 yrs ?
    If you look at Prii sales, I think big uptick in 2007/2008 so more coming. So far batt failure rates in 2007-2009 have been much less than 2004-2006, so either the batts improved or, if its just tiime lag, we'll be needing a bigger band width here.
  10. bisco
    49,798
    no, i mean a lot of first time posters, coming here with problems, but lacking clarity and good communication skills.:cool:
