12v battery Issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Christian_cool, Nov 16, 2015.
  1. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There is 12V on the OBD port without the car turned on. My Scangauge will read it if I just press the "on" button on it, car off. The Scangauge reads a few things -not- on the digital bitstream with its own A-D converter.
    Christian_cool and Mendel Leisk like this.
  2. CR94
    CR94 Senior Member
    2,642
    1,136
    Northwestern S.C.
    That works, but when I do that, even with all reasonable precautions, my Scangauge shows about 0.2 volts below the voltage at the battery terminals.
    Christian_cool likes this.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    It's the voltage drop between the battery terminal and the OBD2 port due to copper and connector resistance.
  4. CR94
    CR94 Senior Member
    2,642
    1,136
    Northwestern S.C.
    Connectors, maybe. Voltage drop due to copper resistance should be negligible, with such a tiny current. Another possibility is that the thing is simply not very accurate as a voltmeter.
  5. Mendel Leisk
    38,303
    ScanGuage is just reading values through OBD, but yeah, it may be reading inaccurate values. I've noticed some differences, reading with mulitmeter at jump point, vs directly at battery cable. Strange, if I recall correctly: one time voltage readings were slightly lower at the battery.
  6. fuzzy1
    10,069
    You were reading while the car was in Ready mode, in which an inverter from the HV battery is charging the 12V battery.
    Try it again, but with the ignition in Accessory mode instead so that inverter is turned off. This is most meaningful first thing in the morning before the car goes into Ready at all. Or at least when the car has been shut down for several hours.
    ScanGauge is measuring the voltage itself, at the OBD port. That is how it can read voltage when the car and ODB data are not running.
    Christian_cool, CR94 and Mendel Leisk like this.
  7. David Beale
    5,963
    1,981
    Edmonton Alberta
    The power on the OBD port may be going through a diode in the computer (well, -a- computer), in which case there is some drop. I've also noticed the Scangauge reads lower than I would expect, but not enough to worry about. I watch for a loss of a cell, and that's 2 Volts. It's accurate enough to show that. ;)
  8. bisco
    49,049
    buy a ten dollar dvm.
    dorunron and Mendel Leisk like this.
  9. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    ^ ^ ^ What he said! ^ ^ ^
  10. Christian_cool
    Christian_cool Junior Member
    92
    16
    Germany
    Sorry for the late reply guys, i really appreciate you help suggestion, thanks :)
    I have finally imvested in a cheap multimeter to measure the 12v battery voltage which i will do tomorrow. Because i think the obd would not be so accurate in reading the voltage.
    I will give updates of how it is :)
  11. bisco
    49,049
    good move!
  12. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Having and knowing how to use a meter is good. Let us know what battery you end up buying too.
  13. Mendel Leisk
    38,303
    You might want to get a Solar BA5 tester (or similar) too. It does a quicky test of the battery's capacity, Cold Cranking Amps or several other. Also displays voltage.
    Or maybe not: if you're a battery hypochondriac like me, it can be too much information, lol.
  14. Christian_cool
    92
    16
    Germany
    So i am back again and i am still alive! ;)
    What i did: First i measured the voltage of the battery, it show 10,6 volt which i think was nearly at the minimum level.
    So i decided to take out the battery and add some distilled water to the battery.
    I bought some distilled water, took the battery inside the shower room..(just in case) and
    pill of the "advertising to buy a new battery from Toyota" label and gently took the rubber tabs out that cover the holes. I used a flashlight to check how much water there was inside, and surprisingly the battery cells was like covered to only the half! i look on internet and found out that the cells should be covered completely and of course not overfilled... crazy i wonder if the cells have been damaged.. so i filled it up with the distilled magic water, cleaned it and charged the battery with a battery charger. So i drove her around some few times, let the light be on after shutting the car down. The voltage show 12.7 volt! So now i will see how long it stays alive :)
    Robert Holt, bisco and Mendel Leisk like this.
  15. bisco
    49,049
    congrats, all the best!(y)
  16. Christian_cool
    92
    16
    Germany
    thanks i appreciate it :)
  17. David Beale
    5,963
    1,981
    Edmonton Alberta
    Watch the battery voltage carefully. Check it first thing in the morning, -before- you put the car in "ready". I "fixed" the battery in Pearl, a 2007 Prius, in 2010 by adding water. It lasted till this spring. Unfortunately the add water fix didn't work on Pearl S (a 2012 Prius), it looks like the battery is toast. This morning, after sitting for 6 days of no use, the battery was at 8.8V (as seen on the Scangauge) when I tried to put it in "ready". The car went into "ign on", not "ready". No joy. I had to drive the FJ Cruiser! The battery in that vehicle is also original, and 2007 vintage, but still working fine. The Battery Tender is on Pearl S and I'm shopping for a new battery. Wish I could buy one like the FJ Cruiser has, a Panasonic lead acid with removable caps, but they are not sold in North America. Too expensive I guess to compete.
