12v battery replacement cost
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rickster, Jul 6, 2011.
  1. sportcoupe
    sportcoupe Junior Member
    44
    eBay emails me 10% discount codes from time to time. They are good for any item on ebay but can only be used once.
  2. AquaJan
    AquaJan Junior Member
    47
    17
    US
    Just got an Optima Yellow top from Streetsideauto.com for $135.82 with code W371513.
    Shipping was fast and free! (y)
    homwerk likes this.
  3. homwerk
    homwerk Junior Member
    San Diego
    Thanks for the link and code, AquaJan!
  4. Jonathan Padilla
    Jonathan Padilla New Member
    Hey was up, i did your stereo install technigue, it work,
    just curious since im running a 500 watt amp for my sub,
    will this battery damage my car system?
    XS Power D3100
  5. larrypcmc
    larrypcmc Junior Member
    44
    wi
    Hi I just bought a 22nf agm battery with a side vent for 109.88 on EBAY. free shipping out of Illinois. It is 55ah and has flat taped threaded terminals witch seem to be brass. I will put it in this morning.
  6. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    I think the battery you are going to fit is the type of batteries I am using in the UK. See fitting instructions in the post below. These are extremely robust long life batteries with a much greater capacity than the OEM or Optima batteries, and stand up very well to deep discharge being a requirement in there normal use.
    Fitting mobility 12volt AGM battery. | PriusChat
    John (Britprius)
  7. larrypcmc
    44
    wi
  8. larrypcmc
    44
    wi
    Thanks went there Great reading.
  9. Bob the Builder
    Bob the Builder Junior Member
    26
    US
    Optima now has one with the correct post size, a drop in install. I was one who sent them an email about the fit. I can't believe some of the dealers who hose you on the install. A couple of screws for the cover and two post installs?
  10. icharry
    icharry Junior Member
    27
    Los Angeles
  11. JC91006
    16,468
    8,383
    Amazon has been regularly selling this optima battery for $147.xx for the past few weeks. They come in and out of stock throughout the day. And yes the part you have is correct. Optima (8171-767) DS46B24R Yellow Top Prius Battery
    The dealers price of $385 is very high, $200+ on labor alone. It's not a very difficult task, just need simple tools to do it, takes about 20 minutes.
    Daves09prius likes this.
  12. Patrick Wong
    18,198
    6,463
    You want the DS46B24R size since that has the proper terminals.
  13. icharry
    27
    Los Angeles
    So it turns out that the guy at E Learn Aid is in Los Angeles and offered to install the battery for free. Battery was $173 + tax. Comes with a 3 year warranty. I gave him a few extra bucks for good karma. So far so good. Battery showed 12.1 even with load. The guy is a bit of an absent minded professor type but knew what he was doing. Attached a battery so I did not lose radio, odometer and other settings. 30 minutes later I was on my way.
    If I don;t post back here it will be because everything is going good.
  14. JC91006
    16,468
    8,383
    You got a new battery correct? A fully charged battery should be 12.9 volts.
  15. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    I bought a new Exide battery (aftermarket but Prius direct fit) for €75 / us$100 and fitted it myself. Longest time ever for me to fit a battery, but saved me a nice few €s!
  16. Britprius
    5,194
    1,912
    We seem to have a much bigger choice of batteries this side of the pond, but I know the Exide is available in the US. It is an excellent product at a very good price.
    Few people seem know this but they also do a spiral wound battery along the same lines as the Optima. The downside to the spiral battery is it's poor use of "or should I say wasted space between cells" space giving it reduced capacity for the same footprint. This in the case of the Prius battery is a loss of 7 AH in capacity.
    John (Britprius)
  17. Tony D
    468
    132
    Dublin, Ireland
    Very true re choice here. I could have bought an even cheaper "no name" battery, again Prius size for about €55! I prefer to stick with brands that are known and trusted fir the sake of a few extra euro. The Exide also has a greater AH than the standard Toyota battery (can't remember exactly though)
  18. Britprius
    5,194
    1,912
    The capacity of the OEM battery is not marked on the battery. In the US two sizes are fitted depending on the entry system of the car.
    The small battery is 35 AH the larger one is the same as the UK/EU battery and is either 40 or 45 AH no hard data to go on.
    The Exide along with most other Prius fit batteries this side of the pond is 45 AH.
    I use a mobility battery rated at 62 AH over 50% higher capacity than the OEM. The down side to this is a few pounds of extra weight, but the upside is it's large reserves in capacity, and not having to be concerned about use of accessories, and mobility lift fitted in the rear.
    John (Britprius)
  19. icharry
    27
    Los Angeles
    hmm.... the 12.1 was under a load - ie extras turned on... read only 12.5 with no load. Will check again tomorrow.
  20. icharry
    27
    Los Angeles
    I just got a new(?) battery Optima from Specializing in: dictionaries including the Collins Cobuild, Oxford English Dictionary (OED), Webster's & Random House. auto parts, study skills and life improvement and I did the test above listed by dorunron here Prius startup issues | PriusChat
    and these are the scores I got:
    Accessory 12.2
    Ignition On 12 then 11.9 then 12
    Ready 14
    I did this 1st thing in the morning after car sat all night in 50 degree weather. Also when I tried to enter Accessory mode the radio came on - is that right? or did I enter an incorrect mode?
    If this is right is it a bad battery?
    FYI I am also posting to another thread -
    12v battery replacement cost | Page 3 | PriusChat
    hope that is OK.
