12V Passthrough Connections - Dashboard
Discussion in 'Prius c Accessories and Modifications' started by scrull, Jun 21, 2014.
  1. scrull
    scrull Junior Member
    36
    24
    Charlotte, North Carolina
    So, I had some free time today and got sick of staring at my TomTom and Phone charger wires so I decided to make some custom passthroughs into the dash for cables and retract them when I wasn't using them. Here is the result.
    The cables you see there are a micro-USB and the TomTom traffic receiver USB cable. I added velcro to the ends to prevent the cables from falling back through but allowing them to almost be hidden when not in use.
    I basically added a 12V outlet by the OBDII port under the steering wheel column and added an add-a-fuse to the cigarette outlet fuse (15AMP) to power it. Works great!
    #1 scrull, Jun 21, 2014
  2. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    That's pretty cool. Do the cable have some length you can pull? Is the opening for the cables clean?
  3. scrull
    36
    24
    Absolutely. In fact, i'll be adding cable recoilers inside soon. I used a dremel to make a rectangle opening, sanded the cut, then added a rubber grommet to finish the cut. I'd say I probably have about 1ft of cable pull still. It's all zip-tied in a conduit going from the steering wheel fusebox,
    w2kpugsly likes this.
  4. Captain Lucian Chiroptera
    40
    Oregon
    2014 Prius c
    this is what I was just thinking about on my drive back to work on my lunch hour...
    I'm planning on doing something similar, except perhaps in a different location, if I hit any snags, may I PM you for any words of wisdom?
  5. scrull
    36
    24
    Sure thing. If you go the route of drilling, just make sure you have a rubber grommet that you can use to dress it up when its done.
  6. Captain Lucian Chiroptera
    40
    Oregon
    2014 Prius c
    a Grommet? :eek:
    can I use a Wallace instead? :LOL:
    :ROFLMAO:
    scrull and ztanos like this.
  7. GregP507
    GregP507 Senior Member
    3,002
    480
    I went through the main rubber grommet in the firewall. I taped a sharp knife to a stick and made a slit in the rubber. I taped the wire to a wooden dowel, with a Bic pen cap over the end to give it a bullet shape. I sprayed the rubber with WD-40, and I forced through. I reached under the dash, found it and pulled it off the stick..
    The cable recoilers which are common in patch-cords nowadays are easily modified so that they don't lock. Take the label off and the screw out carefully, and pry it apart, careful not to uncoil the spring. Remove the small plastic piece that engages the cogs and put it back together.
  8. Captain Lucian Chiroptera
    40
    Oregon
    2014 Prius c
    I look forward to having the time to do this, don't know when, but it's on my list... :cool:
  9. hlunde
    hlunde Member
    419
    74
    OK, but USB standard is 5 volts and it seems that you connected your devices to a 12.6-14 volt bus?
  10. scrull
    36
    24
    Yes, the connection goes like this:
    12V fuse --> Cig Lighter Socket --> 5v USB Car Adapter @ 1 Amp
  11. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Might as well get a 2.4A usb car charger
