130,000 mile service coming up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by romad, Mar 16, 2016.
  1. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    2004 Prius, 11.583 years old
    What services other than the 5K oil change and tire rotation should be done? Should I just halve the mileage and use the 65,000 mile requirements?
  2. JC91006
    16,470
    8,383
    At 130k miles, the car will need a lot of maintenance items. The question is how long you plan on keeping the car? If the hybrid battery is still original, that can fail at any time, giving you an additional expense of $2000+
  3. jtegf
    jtegf Junior Member
    SUN CITY
    I went back to the Toyota Maintenance booklet and started over at 125,000, performing the items listed for the 5k interval, and proceeded from there to follow the same sequence as the first 120k.
  4. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    No, don't "halve" the mileage, just continue to repeat a periodic maintenance schedule. Some work is required each 5k miles, Some each 30k miles, a few items every 60k miles (I add replacing ATF at this interval), and at 100k mile intervals there are a few new items:
    • Plugs (The book saya at 120k miles)
    • PCV (not mentioned in the book)
    • coolants (both loops) and then repeated at 50k mile intervals
    • I replace both the Engine coolant pump and the electric "Inverter" coolant pump as well as the serpentine belt at 100k intervals as a preventative measure
    JeffD
  5. Mendel Leisk
    38,260
    That's one problem with the US maintenance booklet, it goes service-by-service. If they'd publish a grid-format overview, you'd likely see an overriding pattern to the maintenance.
    I tried converting 130,000 miles to km's (208,000) and entering it on Toyota Canada's grid-format schedule, here:
    Xtime Menu Manager
    (at the above link, click on the "mileage grid" tab)
    You can play around with that. I'd look at what was done previously, too. Has the transaxle fluid ever been changed? Brake fluid? Brake inspection?
  6. romad
    320
    57
    Prescott, AZ
    Yes, the 100K service was the most expensive periodic maintenance service. I had the serpentine belt replaced early also.
    Thanks for the chart, I'll use it to create a spreadsheet so I can keep track.
    #6 romad, Mar 16, 2016
  7. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes and I am approaching 300k miles which may cost more than my trusty 2004 Prius is worth. :(
    JeffD
  8. romad
    320
    57
    Prescott, AZ
    Plan on keeping it until it dies. $2000 is roughly what we paid for the initial steering repair back in 2010. We are actually in a better financial position now than back then.
  9. Mendel Leisk
    38,260
    I did a spreadsheet of the US schedule for the 2010 Prius, but not the earlier 2nd gen:
    2010 Prius Maintenance Schedule (US) | PriusChat
    I just used the US booklet, went through it interval by interval, transferred the items to a table. In the process I noticed a few gaps/contradictions. That interval by interval list is hands-down the worst way to explain something, very unfriendly.
    Anyway, the process didn't take that long, 2-3 hours. If you're going to do that, I'd suggest to just start with the US booklet. If it's lost you can download from Toyota TechInfo (I'll attach it too).
  10. romad
    320
    57
    Prescott, AZ
    Thanks for that link to the files. I'll probably use the Excel file as a boilerplate and then enter the appropriate info for the 2004 model.
  11. romad
    320
    57
    Prescott, AZ
    Mendel. I used your schedule and the 2004 service book to come up with a version for my 2004. For 130,000 miles, I just need the oil change/tire rotation and fluids and brake inspections.
  12. chefHawk
    chefHawk Junior Member
    New Jersey
    I scanned the Toyota 2010 Prius Warranty and Maintenance Guide
    -- i didn't see anything about timing belt, etc. I'm at 140k miles..
    My only major repair has been changing the 12 volt battery.. :) I assume I'll start to have problems with the Hybrid battery... Any thoughts on what those problems might look like? Other suggestions?
    Any other 2010 owners with 140k -- or more miles.. any advice?
  13. romad
    320
    57
    Prescott, AZ
    chefHawk, no timing belt to replace as the Prius has a timing CHAIN. (Click on the word "chain")
  14. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    And the chain will let you know if it needs maintenance by making a lot of noise. My 2004 Prius went 288k miles and 12 years on the original timing chain. Its HV battery went 195k miles and 8 years.
    JeffD
  15. romad
    320
    57
    Prescott, AZ
    Jeff, what did it sound like? Based on your sig, you didn't have it repaired but just replaced the entire car?
