2001 brake booster assembly
Discussion in 'Generation 1 Prius Discussion' started by ChrisLynn, Mar 18, 2012.
  1. ChrisLynn
    ChrisLynn New Member
    Tuscaloosa
    2001 Prius
    My abs light & warning sound have been going off. Dealer indicates an internal short requires whole assembly ("brake booster assy.") be replaced as whole brake system will shut down soon. Price they quoted for part & labor is $1900, which is mostly for the part. They indicated I might be able to find the part cheaper on eBay. I find what appears to be a range from $77-$1100, but I don't really know if this is what I'm looking for. Is anyone able to confirm that these parts are the same thing (obviously, I like $77 better than $1100) & are in fact what I should be looking for?
    OK, apparently I can't post hyperlinks yet, but I searched eBay for "2001 Prius brake booster." if anyone can shed some light on this for me, I'd really appreciate it.
    Thanks!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Call Eric aka Freidawg. He has the most Gen 1 parts of anyone that I know of.
    1-800-508-2211
    Adopt A Part
  3. ChapmanF
    16,029
    It's probably safest to go by part number. You can go to any of the Toyota dealers who list on partswebsite.com. You can browse for parts (don't just look under Brakes, look also in Electrical -> ABS components). partswebsite doesn't show you part numbers, but it lets you search by them, so if an ebay listing has a part number you can look it up here and make sure it's the right part.
    You can also check on toyodiy.com, which gives you part numbers (but it's not an official dealer site, so you might check those part numbers against a partswebsite dealer too).
    -Chap
  4. ChrisLynn
    Tuscaloosa
    2001 Prius
    Thank you!
  5. ChrisLynn
    Tuscaloosa
    2001 Prius
    Thank you!
