2001 generation 1 prius battery
Discussion in 'Generation 1 Prius Discussion' started by simsima, Feb 24, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
  2. simsima
    simsima New Member
    29
    can
    2001 Prius
    Is there anything I should be afraid of when removing the HV battery such as how long I have it out of the car? Is there any sort of time limit working against me?
  3. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    The modules should hold a charge for several weeks. The ones that don't, i.e. 7V or less, are bad.
  4. simsima
    simsima New Member
    29
    can
    2001 Prius
    For everyone who is going to be on in the next few hours: I'm at the shop taking it apart and i have my camera so I can upload the pics as I work if you need to see something
  5. simsima
    simsima New Member
    29
    can
    2001 Prius
    do i need to take the battery out or can i test it while its in?
  6. simsima
    simsima New Member
    29
    can
    2001 Prius
    Ok so i tested, there are 3 bad cells, now im wondering how do i remove the cells. does anyone have a link to something that would explain how to remove individual cells?
  7. simsima
    simsima New Member
    29
    can
    2001 Prius
    Ok so I'm cleaning it up. Took the bolts out and the strips, cleaned the corrosion off them, scrapped the corrosion of the cells (the section thats left after taking the bolts and strips off). Should I be doing anything else to get rid of corrosion and/or do anything else before i install the new cells? BTW: all but 3 cells read 8.12V
  8. Patrick Wong
    18,199
    6,464
    The sense wires that attach to the busbars are very delicate. I suggest you use an ohmmeter to verify that all of the wires are good before you reassemble the battery.
    If you see electrolyte leaking from a module terminal, it would be good to clean that up so that the electrolyte won't provide a ground fault to the battery case.
  9. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Were you able to get replacement modules already?
  10. simsima
    simsima New Member
    29
    can
    2001 Prius
    I cleaned the modules, can you descibe the sense wires better or send a picture if you can find one? I'm waiting for the replacement modules i bought to get here, they should be here my friday or monday. Is there anything I should worry about because I'm leaving everything disconnected for about a week?
  11. Patrick Wong
    18,199
    6,464
    The sense wires are very thin and attach to one of the orange busbars that electrically connect the 38 modules in series.
    There's no problem with leaving everything disconnected. The main concern is that you remember how to put everything back together, including installing the replacement modules with the correct terminal polarity.
  12. ChapmanF
    15,111
    If you don't have good instructions already, and you search around for the service bulletin on battery resealing, the procedures are well described there. (I guess they might not go into removing the screws from the module bottoms to change a module out, but that's all that's left after the disassembly they do describe.)
    A couple key points:
    1. an inch-pound torque wrench when reattaching bus bars, to get the terminal nuts tight enough without overtightening and damaging modules.
    2. a few hours wait period with no electrical activity in the battery (sounds like you're already there) before even thinking of loosening the compression bolts that attach the end plate to the battery carrier and to the rods that run across the top. Oddly, the instructions didn't cover why that's important, but electrical activity creates pressure in the modules and they will bulge or burst if the mechanical compression is released, so it's pretty important. For the same reason, make sure all the compression parts are installed and secured before electrical testing on reassembly.
    Somewhere Bob Wilson has a photo of what overcharging can do to the battery even with all the compression provisions in place. :eek:
    -Chap
  13. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Charging these modules is a very interesting process. When the charger detects the negative delta V and shut off, the temperature is already climbing, and continues to climb for about half an hour. As charging nears full, oxygen is produced at the negative electrode, which then passes to the positive electrode and creates heat at recombination. This recombination process takes a while to complete, judging by the continued rise in temperature after removing the charger. If not kept under compression until the temperature falls back down, the oxygen pressure will cause the module to swell.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Great thread, and promising start.
    OP: work safe, take your time, and good luck!
  15. simsima
    simsima New Member
    29
    can
    2001 Prius
    1. do you know where i can find a free guide? The only ones i've seem are pay only and look like scam websites.
    2. can I charge my own modules? (the ones that are below 7V?) If so, how? I have access to a mechanic garage so i should be able to find the right tools
  16. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
  17. simsima
    simsima New Member
    29
    can
    2001 Prius
    Hmmm interesting... I wish I had seen that before, but I've already purchased enough modules (3) to replace the dead ones that I have... but thats good to know for the future
  18. simsima
    simsima New Member
    29
    can
    2001 Prius
    Do i need to remove the batteries that have not failed to service them? Is there anything I have to clean that I cannot do while the cells are still in place (albeit it exposed)?
    The batteries got to customs yesterday, I doubt they work on the weekend, so I`m expecting to provide the major update on Monday or Tuesday. Say a little prayer for me this weekend :)
  19. simsima
    simsima New Member
    29
    can
    2001 Prius
    Sorry for the delay everyone, the batteries came 4 days late, and my uncles garage has been really busy since they came, so we havent had a chance to put them in yet. will update ASAP
  20. SageBrush
    11,627
    2,530
    Southwest Colorado
    Thanks for keeping us involved :)
    Good Luck!
