2001 inverter problems
Discussion in 'Generation 1 Prius Discussion' started by jarudo, Nov 29, 2011.
  1. jarudo
    jarudo New Member
    MN
    2001 Prius
    I'm a new used prius owner. I've owned it for less than two months and it died. Took it to toyota and the said the inverter went out and quoted me $4,400! $3,200 just for the part. Any suggestions? Thanks. I'm new to this.
  2. jarudo
    jarudo New Member
    MN
    2001 Prius
    My car also only has 67k on it. What should i ask from the mechanic? Should i take it elsewhere?
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Yes, go elsewhere. $1200 for labor is excessive. You need to source a used inverter, cost ranging between $500 and $1000. Try ebay, car-part.com, or adoptapart.com.
  4. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Moved from the Priuschat Shop forum to the Gen 1 forum...
  5. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Maybe the Priuschat Shop should stock used inverters :)
  6. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    723
    Boulder Hybids, Boulder, CO
    Get a 2nd opinion. Find a shop with Techstream, get all error codes and INF/subcodes then post here.
    Also, is your 12V battery healthy? A dying 12V battery can cause all kinds of trouble...
    Used inverter is the way to go...not that hard to install, around 2 hours if you've never done it before and are comfortable wrenching...just remember to properly bleed the inverter cooling system when done...then bleed again a day or two later after driving somewhat to make sure all the air is out.
