2001 prius code p3001
Discussion in 'Generation 1 Prius Discussion' started by yotatoter, Dec 27, 2012.
  1. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    once more I find my self needing more assistance from all you fine folks out there. I have a 2001 prius that I bought from a garage . To get to the point, it had a dead battery pack so I put a good used one in. It will start and run but I keep getting code p3001 which indicates a bad battery ecu. I replaced the battery ecu to the original one that was in the car ,but I still keep getting the code along with all the lights. I did some looking and was told to replace the HV. ecu which I also replaced ,but it did not solve anything. I unplugged a harness while it was running and than got code p3100 which indicates HV. ecu failure.. So I am not sure what is going on ,talked to toyota tech and he said it does not need to be reprogrammed ,but you have to buy a new one as the vin # in the ecu will not match up.. any help out there for me???thanks
  2. bwilson4web
    16,489
    I can't help you until you get your own, Prius aware, OBD scanner. Feel free to search this forum for the options. Sad to say, Ohio is not quite a 'day trip' from Huntsville so I can't run up to 'lend a wrench.'
    yotatoter likes this.
  3. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Thanks will do..
  4. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Okay so sorry for the delay,I finally got my Autoenginuity scan tool in and bought the toyota enhanced version. Any how I plugged it in and played with it a few moments. I now have codes p3000, and p3001 from the HV ECU, and from the Bat ECU I got p3009. So I now assume that the p3009 is in the battery because it comes on the minute you turn the key on and you can not reset it without it coming right back on. The bad thing is this battery has on 30k on it and I believe it because when I picked it up it looked brand new inside. It did not have corosion or the BAD green blue stuff on the terminals so I did not bother to spend much time taking it apart. I guess now it will come back out of the car so I can go over it. Hope this will fix all my codes.. I will update ,but it takes me a while as I do this on the side and I am very busy.. Thanks for all the input....
    bwilson4web likes this.
  5. bwilson4web
    16,489
    I'd like to suggest reading the 19 module pair voltages while you're at it . . . 'carpe diem'.
  6. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Thanks I already got those,they are all within like 0.3volts of each other. They were all at 78 % soc also. I have another 01 that I bought with a known good battery pack. will switch packs and find out if codes go with the pack..
  7. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Plan to work on the car tomorrow after noon ,so I will post back tomorrow night with an update.. On the bright side, by the time I get done with this mess I will be more educated than I was before I started and might be able to point somebody else in the right direction....
  8. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Okay ,so here is the update I promised. The good news is,The battery pack is good. I swapped it to another 01 prius and it worked perfect. The bad news is,well I am not sure yet if its in the main harness or transmission. It appears to have a different trans put in,but I pulled the pan and drained the oil when I got it and it all looked good. It also appears to have a different invertor put on so the fun begins..Now I have more questions than answers ,Was the main pack dead from sitting for a couple years and was the reason it was sold because of p3009 and p3001? SO far the codes are still from the hv ECU p3000 and from the bat ECU p3001,and p3009. I welcome any input at this point,as I am kinda at a loss.. But I will get it figured out...stand by for updates .. I will try to update thu.
  9. bwilson4web
    16,489
    Just to make sure:
    • P3009 stayed with the vehicle after the battery swap and did not go with the traction battery?
    Ok, now it becomes harder. The typical way of fault-isolating a resistance path to ground is a MEGer but these use high voltages to test insulators but these voltages are risky for electronics. If you have or can borrow a MEGer, disconnect MG1 and MG2 from the inverter and test the transaxle for leakage to frame ground without the inverter. Then test the cables disconnected from the inverter and battery. If no luck, it suggests the inverter may have a problem.
    You're in a new area and we're interested in your progress.
  10. bwilson4web
    16,489
    Another approach to P3009:
    The fault is found by finding the part closest to ground.
    GOOD LUCK!
  11. ChapmanF
    18,880
    Bob, that looks like a nice technique. Is it possible the diagram has a couple small typos?
    The large equation Vmeter = Vpoint * Rmeter / (Rmeter + Rleak) seems to be correct (if I'm looking at this right).
    In working the example, though, you seem to have evaluated Vpoint * Rleak / (Rmeter + Rleak) ... which will give a very different result when Rmeter is large and Rleak is small.
    Also (though this is only a quibble) the diagram suggests leak-to-ground (< 1 MΩ) and then the example uses a 5 MΩ leak.
    I notice you use 14.4 V in the example, same as a pair of modules, just as the ECU voltage taps are laid out. Do you think this technique might lend itself to a quicker procedure by creating a deliberate leak of some known, safe resistance at one end of the battery, then using a scantool and the ECU voltage readings?
    -Chap
  12. bwilson4web
    16,489
    I was more interested in sharing the technical approach and as you've pointed out, there are subtle aspects that need to be considered. Also, it presumes the existence of a single 'Hi Z' fault to ground and in the real world, there may be more than one.
    My hope is we might collaborate on a general approach, perhaps one not so dependent upon having a MEGER. Better still, one that can handle ground faults outside of the traction battery as in this case.
    What we want is a non-destruct, safe protocol for finding ground faults that may be in either the inverter or inverter-to-motor circuits. This is not a trivial problem but one I don't think is well documented in the maintenance manual (or my memory of those sections.)
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    Since we're talking about P3009, here's a procedure I've posted b4. It really seems like it should isolate the fault. No megger required. Here it is:
    Prius P3009 High voltage leak code
    I want to share a simple, but very accurate method of determining the source of high voltage leak codes on the Toyota Prius.
    The first step is to clear the P3009 trouble code and then turn the key or push button to key on/not ready mode, (This is IG ON on a Gen I or the second position on the ignition switch (after ACC)) wait 30 seconds and if the code comes back, the leak is in the battery case. If the code does not set, turn key or push button to "ready mode"(start on the Gen I) and immediately shift to neutral and stay this mode for 30 seconds. If the code returns, the leak is in the power cables or inverter. If the code did not set, shift to drive and if the code resets now, the leak is in the transaxle. This is something that can be done in about minutes with a scan tool while never removing any components and not leaving the driver seat.
    Keep in mind we're looking for the P3009 code to come back so a scanner of some sort is necessary.
    Does anyone see any reason why this wouldn't work?
  14. bwilson4web
    16,489
    The only problem I can see is the unknown about how long a ground-fault has to exist before the code is set. I don't know that anyone has done that experiment ... but I may have occasion to in the future.
    I'm seriously looking at an upgraded inverter for my wife's 2010 Prius provided I can find space to mount it under the passenger bench. IF SO, then I have no problem with tapping the traction battery as a power source to that inverter and with a high-voltage fuse (aka., think solar panel type), in it goes.
    What I don't know is if the high-voltage terminal taps are going to see a ground-fault in the 3d party inverter so there will be a test.
  15. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    I finally got back from trip,so I have not had much time to work on the car.
    Let me try to explain in better detail what the car does. If you turn the key on without starting the car,the code appears immediately, and you can erase the code but it comes right back within 3 seconds. I thought it was the battery pack ,but i put the battery pack in a different prius and there were no codes and the car drove perfect. I do not believe it is in the trans. as you do not have to start the car for the code to appear,however from my understanding the next logical point would be invertor. Has any one tried to remove the 2 high voltage lines from the invertor and use a multi meter and check voltage to vehicle ground? thanks for the help so far,I will keep you updated..
  16. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    734
    Boulder Hybids, Boulder, CO
    Yes, you can unhook the two big orange connectors at rear of inverter and test to ground. If there's a leak it's usually so small you may not detect is without a megger (aka insulation tester). This is part of the full troubleshooting procedure in the Gen1 service manual, Arts talks about it a bit here.
    Prius 1st gen - Replacing Transaxle
    If P3009 is because of bad MG2 in the tranny, you may be able to detect it with a normal ohmmeter instead of a megger...since the winding are often burned up real good. Remove wiper cowl stuff, open the black rectangular HV wiring cover on the inverter. (this covers the orange MG2 wires).
    Unhook MG2 wires from inverter, hold them "in the air" and test each of the orange leads to chassis ground with a regular Ohmmeter. If you have a bad enough MG2 the ohmmeter will register a dead short and no megger is needed....just a new MG2 stator :)
    You can check MG1 HV wires too (the round connector) but I have yet to see MG1 electrically fail.
    yotatoter and bwilson4web like this.
  17. usnavystgc
    3,159
    990
    Tucson, AZ
    Judging by the test, it clearly points to the battery case. I know you put it in another G1 and it worked fine and I can't explain that.
    The person who came up with this test is the owner of ReInvolt. You might try contacting/emailing him to see what he says.
    If we look at this logically, putting the car in IG ON (not ready) would exclude the transmission and the inverter from the loop. With that in mind, we can only assume that a connection to the batt pack (in this car) is bad (since it works fine in the other car). The fact that the light comes on right away with IG ON, clearly points to the battery (and associated components) and away from the transaxle and inverter.
    If it were me, I would try to isolate the batt case from the car (with a rubber mat or something) and see what happens. I would also try to contact ReInvolt to see if he could expound on the test and offer advice for your specific situation.
    Pls know that I'm not anywhere near an expert and don't claim to be. I'm just a guy that is trying to come up with ideas to help you. Approach everything with caution and please double check my logic.
  18. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Well I know I am no expert either but from the way I understand it,that test does not exclude the invertor. The reason for my thinking is that when you turn the key on engine off, the invertor powers up and charges the 12 volt battery. At least it does on mine. Now I do not know whether it gets any power to the transmission at this point but I do not believe so,because the engine needs to be running before the car will move. Thanks 3prong paul for your info. Yes you are correct from what I have experienced also. But I do not think this is in the transmission as it drives fine and there are no grinding noises from the trans. when you coast in neutral. I will try to give you an update this Sat. Thanks for all the good help..
    usnavystgc likes this.
  19. ChapmanF
    18,880
    What did you observe that led you to conclude that? On mine, if I measure voltage at the 12 volt battery terminals, it does not change from the rest voltage (12.72 or lower) to the charging voltage (13.8) until the car is put in READY.
    Another way to think about it is to remember that any power the inverter can use to charge the 12 volt battery must be drawn from the traction battery, and the system main relay doesn't close until the car is put in READY. That information's in the manual.
    Hope this helps,
    -Chap
    Edit: hmm, do we know for sure that your system main relay actually opens when you turn the car off? An SMR stuck closed might explain various strange symptoms including your car charging the 12 V in a condition where ours do not. It would also complicate your diagnosis of a ground fault, to say nothing of endangering you in the process, so it's probably worth ruling out.
  20. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Okay , I might be confused here. By ready you are saying the key in the on position prior to starting it? That is what happens on mine. I turn the key to the on position and in about 2 seconds the ready light comes on and you can see the head light get brighter ect. I forgot to mention you can also hear the main relay clicking in the back of the car a split second before the ready light comes on..My car has 4 key positions off ,acc, on, and start. MY BAD. I AM CONFUSED. I was wrong ,my ready light does not come on till I hit start..I am sorry for the mistake.....
