2005 Prius already has XM integrated, want ipod/iphone music connectivity
Discussion in 'Gen 2 Prius Audio and Electronics' started by DPIStorm, Dec 27, 2010.
  1. DPIStorm
    DPIStorm New Member
    42
    Big Bad Los Angeles
    I apologize in advance if this has been posted numerous times, but I have a 2005 Prius and I added the XM OEM kit a while back which integrated nicely to my car.
    I'd now like to add an iphone / ipod jack if possible but I recall reading a few years ago this was not possible due to the XM taking up the only external connection to the stock radio or some type of interference when XM and and Iphone/Ipod were hooked up. Is this still the case or is it possible to have them both integrated to the system? If so, how?
    Thanks
  2. tf4624
    tf4624 Active Member
    527
    51
    My guess is yes if you have a splitter, but that would only work if the car lets you chose the AUX and have the xm have seperate on off swith so when one is on the other item is off on the OEM cd player.. cant tell you right now cause i have aftermarket with everything built in.
