2005 Prius battery terminals
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tom1l21, Aug 5, 2016.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    About 6 years ago I replaced my oem battery with an optima. The optima came with larger terminal clamps than the Prius comes with. I discarded the original clamps without thinking much of it. Today, my battery finally died and I am looking to replace it with a cheap stock battery. Problem is, the stock (non-optima) batteries all have the skinnier posts that will not allow my clamps to screw down without significant play.
    My two options are to buy another optima or find someplace that sells the clamps for a Prius battery. Any suggestions? Ordering an optima will put me out several days with no car.
    Ive attached a photo showing my old optima with thicker posts and larger clamps compared to an off the shelf Prius battery.
    48,999
    dealer? where will you buy the battery?
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I went to a dealer today, they said they ddnt have the parts or knew of where they would be. I'm going to try another tomorrow.
    48,999
    you can also try some auto parts stores and batteries plus, for an off the shelf battery.
  5. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I tried several different auto parts stores, the best I could do is to get a D51 size battery with the larger terminals on the opposite side (short side) of the battery. The fit is a little tighter with the large battery pack vent sort of in the way. Also, the 12v battery vent hose will not reach due to the vent being on the other side, so I will nees to extend it. Such a headache.
  6. bisco
    48,999
    maybe buy a jump pack, and order an optima.
  7. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Using an optima is my solution. I still find it insane that auto part store don't sell the terminal clamps for the skinny terminals. They sell the batteries with them but not the clamps for that size.
  8. bisco
    48,999
    agreed.
  9. DLW1953
    DLW1953 New Member
    Folsom, CA
    I am new here and don't know how to start a new post, but while we're on the subject of batteries, is the battery the only place to access the terminals for a jump start? I thought they had terminals under the hood but I can't find them. I have a 2007 Prius. Thank you for assistance. And good luck with the battery post situation.
  10. bisco
    48,999
    yes, it's inside the fuse box. it shows it in your owners manual. there's a red cover you flip up, and a terminal underneath, with metal on one side. negative goes to a clean nut or bolt.
    you can start a new thread by choosing the correct forum. then look in the upper right for 'post new thread'.
  11. DLW1953
    DLW1953 New Member
    Folsom, CA
    Thank you so much. I'll check out this new info!!!
