2005 tow home
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kinglew, Oct 28, 2014.
  1. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    install new re manufactured battery at 120375 miles all was well 435 miles later 120810 car would not go into ready mode tow home by aaa torque reads good soc of charge red trangle on mfd also dash lit like xmass tree/
  2. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Going into READY mode, is generally a bad 12v battery, nothing to do with the hybrid battery. Actually a bad 12v battery will sometimes cause people to mistakenly replace the HV pack because all sorts of weird codes are thrown.
    Step 1, replace 12v battery and report back.
  3. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Battery new by dealer 10/13
  4. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Try to go into ready mode but doesnot
  5. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    any toyota teck that can help please post.thanks in advance
  6. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    12V battery or hybrid battery. They are different.
    And a "new" battery doesn't always mean a good battery. When the car is not in READY mode, the HV pack is completely disconnected. If the pack was completely dead or functioning perfectly it doesn't matter since it is physically disconnected from the vehicle through relay disconnects. So if the car is not going into READY, your problem lies with the low power 12v auxiliary bus and has nothing to do with hybrid anything.
  7. JC91006
    16,470
    8,383
    Who did the remanufacturing of the hv battery? That most likely is your problem.
    You can reset the car and it'll start and get into Ready mode again, but that won't fix your problem.
  8. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Revolt now its dormain state of charge is good
  9. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Your cryptic responses without actually answering anything are useless and you won't get much useful help that way.
    "State of charge" OF WHAT is "good"? 12v battery? HV battery? How can you check the SOC of the HV battery if not in READY mode? How do you determine "good"? What can look "good" to one is poor to an actual engineer.
  10. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Relays make
  11. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Stat of charge check by toorque also mfd dispay prius power up but does notget ready torgue reads cells voltage tstate of charge also 12 volt batery prius willnot go inreverseordriveno readycan read withtorque
  12. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Have you checked the big HV battery interlock switch? If that is not seated properly (and it often looks good but isnt) then it wont go READY. The fact that the car worked for a while after HV replacement, then died suggests the problem lies elsewhere.
    Most of the time, it is the 12v battery. Get a voltmeter on it.
    Have you checked
  13. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Battery can be read by tourque android blue tooth soc of hybrid 60 % 12 volt 12.2 volt. Mfd shows 6 bars relay engersoze. for hybrid ready light try to go on but does not .can read with torque no problem read all cell groups 1 - 14 .rebuilt old hybrid battery drove for 2000 miles did balance . Had more bad cells bought replacement install it put on 435 miles drove towork 45 miles every day no problems till
    today
  14. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Yes also charge with trickle charger battery 12.6
  15. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Relays made electrician by trade
  16. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    What DTCs does Torque provide? You should have codes if the triangle of death is displayed. Are you able to get into ACC mode?
  17. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    First thing I check plug I
  18. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    If the plug is not in relay donot engerize.they engerize
  19. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Thanks for all the replys.iam looking for a toyota teck that can steer me to failed componet thanks all who try to help me
  20. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    No codes have vcd techstream purchase try ge it to work need the right driver try a couple no luck yet win 7 32 bit
    #20 kinglew, Oct 28, 2014
